Marcelord Posted July 27, 2013 Report Share Posted July 27, 2013 Hi, sorry for my bad english (i speak Spanish) I had installed Wise Folder Hider when using XP, but now i have Windows 7, the problem is that i forget unhide my folders before install Windows 7, and now i can't access my folders that i had hide before on XP. The hiden folders are not displayed today when i execute Wise Folder Hider. How can i unhide my folders now? Thank you so much! //This solution don't works for me Mathewwine, CoesseBypeLow, BrianDob and 5 others 8 Link to comment Share on other sites More sharing options...
J.P Posted July 27, 2013 Report Share Posted July 27, 2013 Hi and welcome, Marcelord You're pretty good at English for we can fine read it If you upgraded your computer from Windows XP to Windows 7 and not reformatted the hard drive during installation, you should be able to retrieve your files in the Windows.old folder. 1. Click the button Start, and then click Computer. 2. Double-click the drive on which Windows is installed (usually drive C: ).3. Double-click the folder Windows.old.4. Double-click the folder Users.5. Double click on your username.6. Open the folder containing the files you want to get. (If for example you want to get the files in the folder My Documents, double-click My Documents.)7. Copy and paste the files from each folder to a folder in Windows 7 (If for example you want to get everything from the Documents folder, copy all the files and folders and then paste them in the Documents library in Windows 7) 8. Repeat steps 5-7 for each user account on the computer. ----------------------------------------------------------------------------------------------------------- I hope you can use this solution - it has saved my day many times Regards JP J.P, april and Marcelord 3 Link to comment Share on other sites More sharing options...
april Posted July 29, 2013 Report Share Posted July 29, 2013 JP is right, you can try that way. Thank you for supporting our software. J.P, Pinkbus and Marcelord 3 Link to comment Share on other sites More sharing options...
Marcelord Posted July 29, 2013 Author Report Share Posted July 29, 2013 Thank you very much J.P That's the big problem, I've reformatted my hard drive (drive C:) on which Windows was installed, the hiden folder is in drive E: and this is not formatted. All the best! Hi and welcome, Marcelord You're pretty good at English for we can fine read it If you upgraded your computer from Windows XP to Windows 7 and not reformatted the hard drive during installation, you should be able to retrieve your files in the Windows.old folder. 1. Click the button Start, and then click Computer. 2. Double-click the drive on which Windows is installed (usually drive C: ).3. Double-click the folder Windows.old.4. Double-click the folder Users.5. Double click on your username.6. Open the folder containing the files you want to get. (If for example you want to get the files in the folder My Documents, double-click My Documents.)7. Copy and paste the files from each folder to a folder in Windows 7 (If for example you want to get everything from the Documents folder, copy all the files and folders and then paste them in the Documents library in Windows 7) 8. Repeat steps 5-7 for each user account on the computer. ----------------------------------------------------------------------------------------------------------- I hope you can use this solution - it has saved my day many times Regards JP april 1 Link to comment Share on other sites More sharing options...
khan6575 Posted August 17, 2013 Report Share Posted August 17, 2013 hello i have the problem with WFH i hide some folders in previous window i boot a new window (window 7) and i cannot saw my folders,my drive has the space but these folders cannot open what can i do please give me a wise advise about this issue thankx..the above trick was not working i dont have any winold folder in my system drive plz help Link to comment Share on other sites More sharing options...
april Posted August 30, 2013 Report Share Posted August 30, 2013 Please find a PC which has the same system with your previous windows , install a Wise Folder Hider, and follow the instruction below to retrieve your folders. Please follow the instructions below to recover your files. 1. Unzip and install the file downloaded from the link below. http://www.wisecleaner.com/tools/WDR.zip 2. Open the main surface of the tool, choose the drive you used to place the files hidden. Then click "Search". 3. Find a folder named "...." (yes! just four dots!) in the left column. Then click the arrows below until you find the folder named "hide". 4. Click on the folder named "hide", a list of files will show up in the right. 5. Select the files you want to retrieve, and click "Restore" at the right bottom corner. 6. In the incoming pop-up, save the files to a different drive (important!). 7. Open the specific folder in the different drive you chose in 6, voila! Thanks. ariefuat 1 Link to comment Share on other sites More sharing options...
ariefuat Posted September 4, 2013 Report Share Posted September 4, 2013 I forgot my password login and i have encrypt code B97D9B8F668F. Could you show my password?. Thanks Link to comment Share on other sites More sharing options...
april Posted September 4, 2013 Report Share Posted September 4, 2013 Could you please send a email to [email protected] ? There, you will find people who will help you retrieve your password. Thank you for supporting our software. Link to comment Share on other sites More sharing options...
ezquerd Posted September 24, 2013 Report Share Posted September 24, 2013 Is there a program that can translate the encrypt code? If there can i get it? thank you so much. Link to comment Share on other sites More sharing options...
april Posted September 24, 2013 Report Share Posted September 24, 2013 Please just contact [email protected] You will get help there. Thanks. Link to comment Share on other sites More sharing options...
Dennis72 Posted November 7, 2013 Report Share Posted November 7, 2013 Hi, I have used this program tot hidden a directory on a usb stick. But when i restart the program i see an empty field, no sign of the hidden directory. I do not know how i can get the hidden directory back, how can i solve this ? Link to comment Share on other sites More sharing options...
deeku Posted November 25, 2013 Report Share Posted November 25, 2013 how to get my unhide password back in this wise folder hider because i forgot my password.plz,help me. Link to comment Share on other sites More sharing options...
WiseCleaner Posted November 26, 2013 Report Share Posted November 26, 2013 Hi, If you forget your password, please contact our support team: [email protected] Link to comment Share on other sites More sharing options...
moataz Posted April 14, 2014 Report Share Posted April 14, 2014 helllo,fist i want to thank you for this grate program,but ATM I've tried what you said about the recovery and yet nothing is recovered,i facing a real problem here as i was using the Wise Folder Hider ,but i had to install a new windows ,and now i can't see or access the files which is urgent for me ,tried many times the solution of using the recovery and nothing is shown up,i can see the files by the recovery tool but i can't neither recover them or access them..appreciate your soonest reply Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 14, 2014 Report Share Posted April 14, 2014 Hi moataz, In the search box of WDR, don't type any words. Try again! moataz 1 Link to comment Share on other sites More sharing options...
moataz Posted April 14, 2014 Report Share Posted April 14, 2014 Hi moataz, In the search box of WDR, don't type any words. Try again! well thanks really and appreciate your concern and help, but i found another solution maybe it helps other who had the same issue ,i simply installed the wise folder hider in the new windows and made the same password,for some how i was able to find all my files back in WFH without any problems and i was able to access them without any issue or recovery. hope that this will helps any one got the same problem ,and once again thanks admin for your help Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 15, 2014 Report Share Posted April 15, 2014 It's nice, you solve your problem and share it to us. Link to comment Share on other sites More sharing options...
death drive Posted May 5, 2014 Report Share Posted May 5, 2014 Hi, sorry for bad english I have used this programme to hidden a directory on a usb harddisk. i don't do window. i hide the files in my lappy with windows 8 pro on hdd . then i connect the hdd in the desktop pc i tried to delete the .... folder , then when i connect hdd in my lappy i found no hidden folder in wise folder hider hidden in my hdd but i can see the hidden folder hidden in my other drives on my lappy. i tried every thing as i reinstalled the software & put the same password but found nothing. i tried to install the software in other lappy with same hardware & put the same password but found nothing. i can see the folder with glairy utilities disk analysis but i can't cut or copy them . please help me , there is 380 gb data hidden in hdd. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 6, 2014 Report Share Posted May 6, 2014 why did you try to delete '....' folder? I'm not sure following steps can help you to get back your hidden files, you can try it: 1, Click Here to download a tool 2, connect the HDD in your desktop computer 3, run this tool 4, select your HDD drive, then click Scan 5, find out '....' folder and expand it 6, select your hidden folder and click Restore I think it may cost many time to restore your files. Link to comment Share on other sites More sharing options...
death drive Posted May 7, 2014 Report Share Posted May 7, 2014 I was explaining my friend that you can't delete the "....." folder.Thus i tried to delete the "...." folder.I tried the wise data recovery tool but you can see in the picture that it's displaying that the hidden filesare lost but i tried to recover one of them but it didn't play.But in the other picture of glairy utilities disk analyser, you can see that all the hidden folders arethere. Please help me. Can't you improve the wise folder hider like "kaka soft advanced folder encryption"software, it display the hidden folders in other pc's and other virsons of windows. Link to comment Share on other sites More sharing options...
death drive Posted May 7, 2014 Report Share Posted May 7, 2014 how to add pictures in it? TimothySl, AppeptGause and IrvingFies 3 Link to comment Share on other sites More sharing options...
xilolee Posted May 7, 2014 Report Share Posted May 7, 2014 How to make screenshots (aka snapshots) and post them here in this forum, either through the forum itself or through Wise PC 1st Aid Link to comment Share on other sites More sharing options...
saurabh28k Posted May 10, 2014 Report Share Posted May 10, 2014 am gettting error as followingThe following folder/file can't be unhidden.*When I try to "unhide" it, it literally shows this message:The following folder/file can't be unhidden: Pictures Error Message: Access is denied.Can I system restore, to get all the things I had before downloading your software, then undo system restore to get back the documents I made for work after downloading your software, PLEASURE TELL ME MY PICTURES, VIDEOS, AND DOCUMENTS aren't lost forever, there has to be some way to restore what I had before downloading your software, and after I downloaded it.i have also tried wise cleaner..it shows my files but can not restore it..after i press restore..it just gives folders withPLEASEL HELP!!!i am cryingbasic description of your system-windows xpSpecific error codes and/or warnings received-these files can not be unhidden and then access is deniedAny software or hardware that you recently installed or removed-noneAny recent changes that were made to the system-noneThe amount of time that that you have experienced the problem-24 hoursThe things that you have already tried to troubleshoot the problem-all you have mentioned in discussipon Link to comment Share on other sites More sharing options...
namanlove90 Posted May 26, 2014 Report Share Posted May 26, 2014 Hi, Don't worry if you have hidden your IMPORTANT DATA, that you want to recover at any cost, so first of all you don't have to pay a single penny from your pocket. Now if you have installed new OS , then still you can get your data. Follow the steps below exactly and carefully : 1.) Download WinRar (which is free to download and use) 2.) Install WinRar in Your system. 3.) After successfully installing winrar, Open Winrar and follow these sub steps : a.) open WinRar b.) Go to "Command" Tab c.) Under the command tab list choose "view file" d.) choose the drive to view files ( hidden files) 4.) Now you will see a folder name in dotted like this --> "...." . open this folder 5.) now follow this path and keep open the folders to reach to your Data Files "..../00000/..../hidefolder/hide/" 6.) Now you have reached to your data files path and select your files or folder whatever you had hidden by wise folder hider, select your files or press ctrl+a to select all files 7.) now right click on selected files and choose "Add files to archive" 8.) a window will open, you dont have to change the settings, leave it as it is, browse to the folder where you want to extract your locked data and save it by any name Note: it will get saved in rar extension file format, later you can access your files using winrar to extract your rar files 9.) The End, Hi5 you have collected your locked data. email me if you want more help [email protected] with the subject "HELP". Thank You Guys I hope You would like my trick. Link to comment Share on other sites More sharing options...
Raviraj Posted June 6, 2014 Report Share Posted June 6, 2014 Please find a PC which has the same system with your previous windows , install a Wise Folder Hider, and follow the instruction below to retrieve your folders. Please follow the instructions below to recover your files. 1. Unzip and install the file downloaded from the link below. http://www.wisecleaner.com/tools/WDR.zip 2. Open the main surface of the tool, choose the drive you used to place the files hidden. Then click "Search". 3. Find a folder named "...." (yes! just four dots!) in the left column. Then click the arrows below until you find the folder named "hide". 4. Click on the folder named "hide", a list of files will show up in the right. 5. Select the files you want to retrieve, and click "Restore" at the right bottom corner. 6. In the incoming pop-up, save the files to a different drive (important!). 7. Open the specific folder in the different drive you chose in 6, voila! 4KE(E3(5A}1CS)`QH{8S5.jpg Thanks. I tried this. It restored the folder to the other drive BUT the folders were empty. I could still see the files hidden inside the folders in wise data recovery window. Then I tried restoring single file on other drive but that file just DID NOT get restored. This is really irritating. I am at my wit's end . Some of the hidden files in other drives got overwritten. Please help! Link to comment Share on other sites More sharing options...
