wisecleaner_admin Posted May 6, 2020 Report Share Posted May 6, 2020 Hi xilolee, Long time no hear you, how are you. Thanks for your feedback, we will improve it in the next version. Link to comment Share on other sites More sharing options...
Rajat16 Posted May 15, 2020 Report Share Posted May 15, 2020 Any Updates? Link to comment Share on other sites More sharing options...
tipstir Posted June 21, 2020 Report Share Posted June 21, 2020 System specs and processor speed it's not detecting AMD A8 APU shows it as 2 cores with 3 temps. Suppose to be 4 cores, 4 threads and 4 temps under 5.5.4 Pro. Link to comment Share on other sites More sharing options...
tipstir Posted July 5, 2020 Report Share Posted July 5, 2020 System specs and processor speed it's not detecting AMD A8 APU shows it as 2 cores with 3 temps. Suppose to be 4 cores, 4 threads and 4 temps under 5.5.4 Pro. Same issue with 5.5.5 Pro still showing only 3 cores not 4 cores for temp. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 6, 2020 Report Share Posted July 6, 2020 @tipstir Thanks for your feedback. We will check for it. Link to comment Share on other sites More sharing options...
samiswise Posted May 22, 2021 Report Share Posted May 22, 2021 Hi, Would you consider adding a disk usage analyzer like WinDirStat or TreeSize? I think the basics is already there with Big File Manager. Thanks. Link to comment Share on other sites More sharing options...
samiswise Posted May 22, 2021 Report Share Posted May 22, 2021 Also if Wise can verify the digital signers of startup items, schedule tasks, services and running processes, and check them against VirusTotal, like in Autoruns and Process Explorer. That would be great. Thanks. Link to comment Share on other sites More sharing options...
samiswise Posted May 22, 2021 Report Share Posted May 22, 2021 In Operating System and Hardware Overview, I would love to have the ability to copy the chosen value as well as export all values to a text or csv file. It is convenient for others to know your system and offer troubleshooting advice. Thanks. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted May 25, 2021 Report Share Posted May 25, 2021 @samiswise Thanks for your suggestions. I will forward it to the developer team. Link to comment Share on other sites More sharing options...
Bartu Posted June 3, 2021 Report Share Posted June 3, 2021 Menu icons are blurring (not clear) after version 5.6.3.559 Display resolution: 1920 x 1080 Refresh Rate: 60 Hz. Windows 10.0 21H1 (19043.1023) Windows 10 > Settings > System > Advanced Scaling Settings > Custom Scaling (119) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 3, 2021 Report Share Posted June 3, 2021 @Bartu Thanks for your feedback. Sorry, Wise Care 365 v5 does only support 100%, 150%, and 200% scaling. We will improve it in version 6, support 100%, 125%, 150%, 175%, and 200% Link to comment Share on other sites More sharing options...
FAM10 Posted July 25, 2021 Report Share Posted July 25, 2021 Hello, It would be great if Wise Care 365 can have the feature of cleaning for all user accounts ("multi-user" full cleaning) when running from an administrator account. Now, that feature is only for the Registry Cleaner. The idea is that this capability be applied to all Wise Care 365 modules such as Useless files, Privacy traces and the rest of the tools. (That feature of full multi-user cleaning is nicely present in CCleaner, where you can select the user or users and the program will work for that selection in all of its tools). Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 26, 2021 Report Share Posted July 26, 2021 @FAM10 Thanks for your suggestions, we will consider it. *^____^* Link to comment Share on other sites More sharing options...
Serenator Posted August 12, 2021 Report Share Posted August 12, 2021 Hello Admin, I noticed that the English language file for Wise Care 365 has not been updated. The current software version is 5.8.3.577 and the language file version is 5.8.1.575. Could you fix it, please? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 13, 2021 Report Share Posted August 13, 2021 @Serenator Don’t worry, the file has been updated, but forgot to update the version number. Link to comment Share on other sites More sharing options...
samiswise Posted August 16, 2021 Report Share Posted August 16, 2021 Hi, I have the following suggestions: 1. Manage scheduled tasks. 2. Switch default action from "Allow" to "Block" in Wise Protection, or let us choose which action should be the default. 3. Easily add startup entries to block list, to prevent them from being enabled again. Thank you. Link to comment Share on other sites More sharing options...
samiswise Posted August 16, 2021 Report Share Posted August 16, 2021 Btw, usually I can update immediately when a new version is released. But this time I'm still stuck in v5.8.1, click "Check for Updates" and it tells me I'm using the latest.. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 18, 2021 Report Share Posted August 18, 2021 @samiswise Thanks for your suggestion. 1. Manage scheduled tasks. The current versions can manage auto startup scheduled task. we will consider it to manage all tasks. 2. Switch default action from "Allow" to "Block" in Wise Protection, or let us choose which action should be the default. The default "block" operation may cause some programs to fail to start. 3. Easily add startup entries to block list, to prevent them from being enabled again Okay, we will try. 4. usually I can update immediately when a new version is released. But this time I'm still stuck in v5.8.1, click "Check for Updates" and it tells me I'm using the latest.. Sorry about that. The first released 5.8.1 has a bug that cannot check out updates automatically. we fixed it and released the second 5.8.1 soon. Unfortunately, you installed the first 5.8.1. Please download 5.8.3 and update it manually. Link to comment Share on other sites More sharing options...
samiswise Posted August 18, 2021 Report Share Posted August 18, 2021 4 hours ago, wisecleaner_admin said: @samiswise Thanks for your suggestion. 1. Manage scheduled tasks. The current versions can manage auto startup scheduled task. we will consider it to manage all tasks. 2. Switch default action from "Allow" to "Block" in Wise Protection, or let us choose which action should be the default. The default "block" operation may cause some programs to fail to start. 3. Easily add startup entries to block list, to prevent them from being enabled again Okay, we will try. 4. usually I can update immediately when a new version is released. But this time I'm still stuck in v5.8.1, click "Check for Updates" and it tells me I'm using the latest.. Sorry about that. The first released 5.8.1 has a bug that cannot check out updates automatically. we fixed it and released the second 5.8.1 soon. Unfortunately, you installed the first 5.8.1. Please download 5.8.3 and update it manually. Great, thank you. Link to comment Share on other sites More sharing options...
