PocketAppZ Posted November 16, 2014 Report Share Posted November 16, 2014 I'd like to see the addition of an Options menu for these two purposes: 1. Option to hide removable drives from drive-select menu. 2. Option to select only the OS drive by default upon program start. RudyJainy, Mablenige, IrvingFies and 2 others 5 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 18, 2014 Report Share Posted November 18, 2014 Thank you fro your suggestion. I will send it to our developer team. Link to comment Share on other sites More sharing options...
PeterM1949 Posted November 23, 2014 Report Share Posted November 23, 2014 Why not have the option to print out the resluts of a search to a printer or to a file?? Seems a pretyy basic sort of request and one many, I'm sure, would find absolutely useful. Especially as you people are so innovative with much of your packages. Israeltric 1 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 24, 2014 Report Share Posted November 24, 2014 A nice idea! Thank you very much. I will send it to the developer team. Link to comment Share on other sites More sharing options...
Star86 Posted July 9, 2015 Report Share Posted July 9, 2015 The latest version 2.12.90 still has the same problem as the previous ones: it can only be run in a Windows user account that has administrator privileges, it will not work in limited user accounts. Can you change the installation procedure so you can choose to make it available to all users on that machine, as many other utility programs do? Not being able to use it in a Windows limited account is EXTREMELY annoying, as that requires having to frequently either switch accounts or go through extra steps in the limited account to run the program as Administrator Link to comment Share on other sites More sharing options...
WiseCleaner Posted July 10, 2015 Report Share Posted July 10, 2015 @Star86 Wise Jetsearch requires administrative to privileges to index NTFS volumes, it will boost up the search speed. But, I will send your suggestion to the developer team, maybe they can improve it. Thank you! Link to comment Share on other sites More sharing options...
dgkmurti Posted July 12, 2015 Report Share Posted July 12, 2015 I find Wise Jet Search very fast and very useful. However, it gives choice to search only from whole drives, like "C", "D" etc. It is fast enough, but, may bring unwanted results. I would appreciate if it shows further tree structure within a drive and allow the user, if he/she wishes do, to search a particular or multiple folders within the Drive. For example: We usually would like too search "My Documents", "My Pictures" etc. folders only and have no interest in searching program folders. Thanks. Link to comment Share on other sites More sharing options...
fernman Posted August 20, 2015 Report Share Posted August 20, 2015 Just installed the portable version today, I'm blown away by it so far, but I already have a suggestion, which is to add an option to allow it to always open full screen instead of having to click on the enlarge button in the top right corner. I don't find the small screen sufficient to see all the details of the results clearly. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 21, 2015 Report Share Posted August 21, 2015 Nice suggestion, thanks! I will send it to the developer team. Link to comment Share on other sites More sharing options...
kolanp Posted January 11, 2016 Report Share Posted January 11, 2016 Searching in the custom folder. There is necessary to an option to select the folders to search by user. The deletion of files is no problem but It could not be deleted the folders in search result. See a captured video below. (not permitted to upload video file) http://www86.zippyshare.com/v/ygGrm3Pg/file.html Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 12, 2016 Report Share Posted January 12, 2016 Hey kolanp, THanks and sorry for the delay. 1, There is necessary to an option to select the folders to search by user. We will consider it, thanks. 2, The deletion of files is no problem but It could not be deleted the folders in search result. Actually, it is not a bug. For security purpose, we want user to confirm each file in the folder is useless and can be deleted. Link to comment Share on other sites More sharing options...
Wisio87BN Posted June 5, 2016 Report Share Posted June 5, 2016 why isn't Wise Jet Search able to search 3Tb external hard disks? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 8, 2016 Report Share Posted June 8, 2016 Hey Wisio87BN, We are working to update wise jetsearch. It will support big disk in next version. Link to comment Share on other sites More sharing options...
Georg Posted July 27, 2016 Report Share Posted July 27, 2016 I'd like to scroll through the results using the Page up and Page down keys. Scrolling through 15907 results moving the scrollbar with the mouse is not precise enough and using the mouse wheel is too slow. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 29, 2016 Report Share Posted July 29, 2016 Thanks for your suggestion. Link to comment Share on other sites More sharing options...
Georg Posted August 19, 2016 Report Share Posted August 19, 2016 Bug Report: WiseJetSearch does not see all disks. When WiseJetSearch has finished looking for volumes on disk 0 it looks for disk 1. If it is not present, it stops looking for other disks. See picture. How can it happen to have disk 4 without disk 1? Perhaps by removing disks 1, 2, and 3. I got it after configuring disks 0, 1, 2, and 3 to a new RAID disk. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 22, 2016 Report Share Posted August 22, 2016 Hey Georg, Thanks for your feedback. DO you install wise care 365? If yes, please open wise care 365 -> System Monitor -> Hard Drive, does it list all your disks? If you have not install wise care 365, please download this file www.wisecleaner.com/tools/diskinfo.zip, then give me a screenshot. Thanks. Link to comment Share on other sites More sharing options...
Georg Posted August 22, 2016 Report Share Posted August 22, 2016 I'm sorry. I'm using Windows 7 and its search is useless. So I did a reboot to get my disks renumbered without a gap. After this I could use WiseJetSearch again. Link to comment Share on other sites More sharing options...
Laz123 Posted August 24, 2016 Report Share Posted August 24, 2016 I'm using the 3.32 version. When you've hidden a file or folden then reopened it after hiding it the result still shows. To hide it again you have to cancel the result then navigate to re-hide/close it again. Why not just be able to click on the result to do this? Thanks for you suggestion I'll put it to the development team. Link to comment Share on other sites More sharing options...
xilolee Posted August 25, 2016 Report Share Posted August 25, 2016 Laz123: I didn't understand if you have a problem with wisejetsearch or wisefolderhider. Link to comment Share on other sites More sharing options...
Georg Posted October 14, 2016 Report Share Posted October 14, 2016 Bug Report: WiseJetSearch does not see all disks. When WiseJetSearch has finished looking for volumes on disk 0 it looks for disk 1. If it is not present, it stops looking for other disks. See picture. JetSearch.jpg How can it happen to have disk 4 without disk 1? Perhaps by removing disks 1, 2, and 3. I got it after configuring disks 0, 1, 2, and 3 to a new RAID disk. After removing disk 3 (deleting the virtual drive using RAID Web Console 2) the problem returned. See picture. Diskinfo lists all my disks after B: but does not list disk B: Shawnroums 1 Link to comment Share on other sites More sharing options...
bung55 Posted October 15, 2016 Report Share Posted October 15, 2016 Questions: In the help there is a settings area - how to get to it? (image on user guide page - http://www.wisecleaner.com/wise-jetsearch-user-guide.html) What does 'Run quick search' do? Suggestions: The program window is a fixed size or full size - make it so you can resize the window to your liking. The preset file specs (images, documents etc.) should be customizable - at the moment if you want to modify the preset it is too awkward (e.g. images has too many options, you then have to make lots of changes to it before searching!) Make a setting to change the font size When I open a document I have to confirm it every time - when I open the same document in File Explorer it opens without a confirmation. TIA, Dave Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted October 17, 2016 Report Share Posted October 17, 2016 After removing disk 3 (deleting the virtual drive using RAID Web Console 2) the problem returned. See picture. JetSearch2.jpg Diskinfo lists all my disks after B: but does not list disk B: Hey Georg, Thanks for your feedback. This issue may caused by RAID, we didn't test wise jet search in RAID. We will check it and fix it shortly, Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted October 17, 2016 Report Share Posted October 17, 2016 Questions: In the help there is a settings area - how to get to it? (image on user guide page - http://www.wisecleaner.com/wise-jetsearch-user-guide.html) What does 'Run quick search' do? Suggestions: The program window is a fixed size or full size - make it so you can resize the window to your liking. The preset file specs (images, documents etc.) should be customizable - at the moment if you want to modify the preset it is too awkward (e.g. images has too many options, you then have to make lots of changes to it before searching!) Make a setting to change the font size When I open a document I have to confirm it every time - when I open the same document in File Explorer it opens without a confirmation. TIA, Dave Hey Dave, 1, I wise jetsearch, there is not a Settings window. Below is the quick search window. 2, when you run wise jetsearch, the quick search window will appear on desktop top right. via quick search window, you can quick open wise jetsearch and search keywords. Thanks for your suggestions. Link to comment Share on other sites More sharing options...
xilolee Posted October 18, 2016 Report Share Posted October 18, 2016 When maximized, the windows taskbar won't be visible. Win10Hx64 Link to comment Share on other sites More sharing options...
