Anti 3 Report post Posted April 26, 2014 Version 2.02.83 The interface says 'drag and drop files or folders to the blank area to hide.' But when you try to do that, the cursor turns to a circle with a cross through it, and the files are not added to the list. Anyone else experience this? 3 pokras, AppeptGause and carpinteyroacr reacted to this Share this post Link to post Share on other sites
xilolee 511 Report post Posted April 26, 2014 Me too.I'm using Windows 8.1 x64 and WFH Version 2.02.83 PORTABLE.And you? Share this post Link to post Share on other sites
Anti 3 Report post Posted April 26, 2014 Yes... WFH v2.02.83 portable with Win7 64bit. It doesn't matter that much if drag/drop doesn't function, but it would be nicer. I need to use the portable version, because I don't have admin permission on the computers where I'll be using my flash drive. One thing I need to test on Monday when I get into work, is whether or not the UAC prompt asks for administration elevation when running WFH.exe. Do you know if it requires admin permission in order to work? Share this post Link to post Share on other sites
xilolee 511 Report post Posted April 26, 2014 I have set UAC on its maximum level and it always asks me admin permission. Anyway, I have now tried to reduce (lower) the level (two times) and the message always appears. I'll (now) try with the installer version, if the drag and drop works ok. Edit: installed, but it doesn't work. Hence it seems that drag and drop function doesn't work, at least using win7 x64 and win8.1 x64. Share this post Link to post Share on other sites
Anti 3 Report post Posted April 26, 2014 Thanks for the confirmation. Share this post Link to post Share on other sites
Anti 3 Report post Posted April 30, 2014 Just to mention, UAC asks for admin elevation on my work computers, so I can't use this program. Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted May 4, 2014 Please try to turn down your UAC level, Default Level is better. Share this post Link to post Share on other sites
Anti 3 Report post Posted May 4, 2014 Unfotunately I have no control over my work computers, so I can't change anything. That's is one of the major problems I'm having in finding a security solution for my flash drive! Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted May 6, 2014 Understand. So, you need to click Hide File/ Hide Folder button to hide files and folders. Share this post Link to post Share on other sites
xilolee 511 Report post Posted May 6, 2014 I lowered the UAC level (and rebooted the machine) to the second option "Notify me only when applications try to make changes to my computer (do not dim my desktop) - Don't notify me when I make changes to windows settings", but the problem persists. (Note that I'm not using WFH, I'm just confirming the issue) Share this post Link to post Share on other sites
frogbone 1 Report post Posted June 18, 2014 Drag & Drop doesn't seem to work. I use the portable version. Share this post Link to post Share on other sites
Topbuzz 0 Report post Posted December 23, 2014 I don't think drag'n'drop has ever worked. I've been using WFH since v1.53 up to v3.13. All of these have been full installs, not portable and running on WinXP up to Win7 64-bit. I just have to keep on manually locating to the folder in question to hide each time. Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted December 24, 2014 @frogbone, If your OS is Windows vista or Win 7, please turn off UAC (Users Account Control) If your OS is Win8/8.1, sorry, drag & drop cannot work in Win8/8.1 Share this post Link to post Share on other sites
Winder 0 Report post Posted April 4, 2016 @frogbone, If your OS is Windows vista or Win 7, please turn off UAC and read the Wealthy Affiliate here https://affmountain.com/my-wealthy-affiliate-review-and-results (Users Account Control) If your OS is Win8/8.1, sorry, drag & drop cannot work in Win8/8.1 Is there any way to get drag and drop to work in Win10? Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted April 15, 2016 Hey Winder, we have fixed it, the latest version v3.31 supports drag and drop function. Share this post Link to post Share on other sites
