WiseAutoShutdow feature requests, bug reports, updated translations
new features
  • Please log in to reply
69 replies to this topic
#41 WiseCleaner
WiseCleaner
    Advanced Member
  • Moderators
  • 1,093 posts
Posted 11 September 2015 - 03:51 AM
Hey xilolee,
Can you tell me your system Date&Time Formats?
  • Stephenhob and XTHighamjak like this
We want to put smile on your face.    :)
News: Halloween 2017
Best Regards,
WiseCleaner.com
Follow us on:
#42 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 11 September 2015 - 04:50 AM
Hi!
All the other tasks work correctly!
However, here it is:
Spoiler
Anyway, in previous versions, every other tasks worked correctly and the bug was present only on the daily task.
If you don't remember/know the (old) bug:
1) open WAS
2) start a daily task, activate/enable it
3) right-click the WAS icon in system tray, exit
4) check the task scheduler: the task will be there (it should be deleted by WAS on exit, like its other tasks)
5) re-open WAS: the daily task is present yet (and running)
(The other tasks were cancelled, instead, after WAS closure.)
#43 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,229 posts
Posted 11 September 2015 - 08:35 AM
Hey xilolee,
Thanks!
Please try this new version of wise auto shutdown.
  • RudyJainy likes this
New product: Wise Anti Malware
Keep your PC in safe all the time!
Best Regards,
WiseCleaner.com
Follow us on:
#44 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 11 September 2015 - 08:42 PM
Hi Ivan!
I forgot to write I'm using the portable version... Anyway I'll try this, of course!
Edit: tried it now: another old bug appears:
1) open WAS
2) start a task (any) and activate/enable it
3) the task will go in the system tray
4) move the task from the visible system tray to the hidden system tray
5) open the hidden system tray (click the little arrow) and you'll find WAS icon (and maybe other icons), but don't move it from there
6) double-left-click the WAS icon
7) WAS should stuck and a window should appear saying something like:
- title: wise auto shutdown
- body: wiseautoshutdown.exe has stopped working - a problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
- buttons on the same line: debug - close program
Video, compressed with 7zip: Attached File  WAS-BUG.zip   1.2MB   15 downloads
Windows 10 standard, Windows firewall, Windows antivirus (defender), WAS version: used yours in your previous post, DEP AlwaysOn, custom scaling level: larger 150% set from Control Panel\Appearance and Personalisation\Display - set a custom scaling level.
I set DEP AlwaysOn from the command line (OptIn is the default setting): bcdedit /set {current} nx alwayson
Edit 17/09/2015 01:00 (italian time):
I have tried now without DEP alwayson (I've set it to optin) and with normal scaling.
The problem remains.
#45 Marek2015
Marek2015
    Newbie
  • Members
  • Pip
  • 4 posts
  • LocationPoland
Posted 20 September 2015 - 05:53 AM
Hi:
Some suggestions:
1.Computer startup feature at the optional times
2.Program Interface color skins including Windows color option
Thank you in advance.
Marek
#46 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,229 posts
Posted 23 September 2015 - 08:02 AM
@Marek2015,
Thanks for your suggestion.
1, Computer startup feature at the optional times.
    Do you means you want setup computer to startup at a specific time? If yes, wise auto shutdown will be defined as Trojans by most antivirus software. So, we can't add this function.
2, Program Interface color skins including Windows color option.
    Do you means you want to custom the interface color?
Best Regards,
WiseCleaner.com
Follow us on:
#47 Marek2015
Marek2015
    Newbie
  • Members
  • Pip
  • 4 posts
  • LocationPoland
Posted 26 September 2015 - 08:50 AM
Hi Admin:
Thanks for your quick reply.
Ad 1 Your program is not defined as any Virus that is why I do not understand that provided with system start up function will be defined as Trojan.
Ad 2 Yes, I mean to custom the program color interface especially to dark background and white fonts like Windows OS High Contrast feature for example.
Marek
#48 hbhhatnagar
hbhhatnagar
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 28 September 2015 - 03:57 AM
Hi!
I've been using this product for a few weeks now and it has been running smoothly till date. I only have one suggestion, if it is possible to integrate. You could add a days of the week feature for the daily shutdown menu. Many people might like their PC shutting down automatically during the week if they forgot to shut down manually but would like for it to stay on over the weekend. You know like the alarm function on most smartphones these days.
Thanks and regards,
Himanshu
#49 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,229 posts
Posted 28 September 2015 - 06:06 AM
You see, Windows power has 5 status, shutdown, restart, sleep, log off, change log, hibernate.
shutdown, sleep and hibernate, all programs will be closed. if you want to start up/ wake up system, you must press Power button or a specific key. A third-party program cannot instead of your fingers.
There is a way to let your computer auto start up, only suitable for your own
1, press Power button to start up, then press Delete key constantly until you enter the BIOS settings
2,  Select Power tab -> Power Up Control, you will see the option Automatic Power Up (or Resume By Alarm), it is Disabled. You can press PageDown, change to Enable, then you will see more options, select Every Day or By Date, when you finish settings, please remember to Save Changes.
I don't know your motherboard model, I can't give you details.
Best Regards,
WiseCleaner.com
Follow us on:
#50 Marek2015
Marek2015
    Newbie
  • Members
  • Pip
  • 4 posts
  • LocationPoland
Posted 28 September 2015 - 07:04 AM
Hi:
After your explanation I was convinced that my first suggestion is not suitable.one. It is not possible to apply to your product. But what about my second suggestion? I will appreciate your reply.
Marek
#51 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,229 posts
Posted 29 September 2015 - 05:41 AM
Hey Marek2015,
Your second suggestion, custom skin/interface color, I have forwarded it to the developer team. They will discuss it.
Thanks!
Best Regards,
WiseCleaner.com
Follow us on:
#52 Marek2015
Marek2015
    Newbie
  • Members
  • Pip
  • 4 posts
  • LocationPoland
Posted 29 September 2015 - 06:20 AM
Hello Admin:
Many thanks in advance.
Marek
#53 mondo
mondo
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 26 December 2015 - 02:46 AM
Hy, I find it really annoying that the time can't be inserted from the keyboar on "From Now" time option. Especially for minutes is really annoying, as one has to do at least 30 clicks on arrows in order to set the needed time.
Maybe you should consider adding keyboard control on all your input fields. I consider this lack of feature a beginners mistake.
Cheers!
#54 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,229 posts
Posted 12 January 2016 - 07:44 AM
Hey mondo,
Thanks, and sorry for the delay.
We will fix it in next update.
Best Regards,
WiseCleaner.com
Follow us on:
#55 testermega7
testermega7
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 03 April 2016 - 05:20 AM
Добавьте в раздел "Выбор задачи" функцию "Будильник". Тогда Ваша программа будет еще круче!
Translated from Russian
Add to the "Task Selection" function "Alarm". Then your program will be even better!
#56 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,229 posts
Posted 15 April 2016 - 05:40 AM
Hey testermega7,
Thanks for you suggestion.
But, sorry, I can't understand it. Can you tell me more details?
Best Regards,
WiseCleaner.com
Follow us on:
#57 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 15 April 2016 - 09:44 PM
He probably wanted to suggest to combine WAS and WReminder.
#58 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 18 October 2016 - 03:14 AM
Portable version creates config.ini in %AppData%\Wise Auto Shutdown: it should be inside the portable folder.
#59 geogeo.gr
geogeo.gr
    Advanced Member
  • Members
  • PipPipPip
  • 52 posts
  • LocationGreece
Posted 17 December 2016 - 08:52 AM
Update Greek translation to WAS 1.55
#60 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,345 posts
Posted 26 December 2016 - 03:11 PM
Hi.
Still present:
Another problem:
  • Create a task (any).
  • WAS should go in the notification area (that's the system tray).
  • Move the WAS tray icon in the HIDDEN notification area (i.e., you must click the up arrow in the notification area to see the WAS tray icon).
  • Click the WAS tray icon in the HIDDEN notification area, and WAS should appear.
  • Click the X in WAS: WAS should go again in the HIDDEN notification area, instead it disappears.
    But it is still present, when you check task manager.
This problem doesn't appear when the WAS tray icon remains in the visible notification area.
I.e., when we/you click the WAS tray icon in the visible notification area, WAS appears; when later we/you'll click the X, WAS will go again in the notification area. This always works (tried three-four times in a row).
Hope this helps (and that it is clear enough).
