Becker Posted October 24, 2014 Report Share Posted October 24, 2014 siehe bild Meldung taucht bei jedem Neustart auf translated from german see image Message appears at every restart screenshot c:\program files (x86)\Search Extensions\Client.exe "c:\program files (x86)\Search Extensions\Client.exe" konnte nicht gefunden werden. Stellen Sie sicher, dass Sie den Namen richtig eingegeben haben und wiederholen Sie den Vorgang. possible english error message c:\program files (x86)\Search Extensions\Client.exe Windows can not find "c:\program files (x86)\Search Extensions\Client.exe". Make sure that you have typed the name correctly and try again. Operating system:Windows 8.1 (64 bit) System root: C:WINDOWS Available physical memory: 3994 MB CPU: Intel® Core i5-3230M CPU @ 2.60GHz Drive Info: C: 426,53 GB D: 25,00 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted October 28, 2014 Report Share Posted October 28, 2014 If you have installed wise care 365, please run it, then click System Tuneup->Startup Manager, can you find a program named Search Extensions or Client ? If yes, please disable it and remove it. If you don't install wise care 365, you can try following: Press Win+R, type msconfig.exe then press Enter to open System Configuration. Then click Startup tab, deselect Search Extensions or Client, then click OK to save settings. Link to comment Share on other sites More sharing options...
xilolee Posted October 28, 2014 Report Share Posted October 28, 2014 It's a malware. You can remove it using adwcleaner, listed in Free tools (Anti-malware, anti-spyware, anti-virus) that you could use to inspect your computer. You can also use the other softwares listed in it: it doesn't hurt! Link to comment Share on other sites More sharing options...
