wdcsea61 Posted May 13, 2014 Report Posted May 13, 2014 I jus updated WiseCarePro 365 and now when I open Wise Care to run diagnostics, I receive the following codes: "Invalid Pointer Operation" and Access Violation at --6EFC84 address in module WiseCare 365.exe" Operating system:Windows 7 Professional (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 8075 MB CPU: Intel® Core i7-3770 CPU @ 3.40GHz Drive Info: C: 119.14 GB D: 1863.01 GB Internet Explorer: 11.0 Robertthaps and janettefb3 2
Requinto Posted May 13, 2014 Report Posted May 13, 2014 Invalid Pointer Operation code Same problem after update. Getting same error: Access violation at addres 006EFC84 in module Wisecare.365.Raed of address 0000002C. Win 7 Home premm 64 bit .Service pack1
bigkid1950 Posted May 14, 2014 Report Posted May 14, 2014 I, too, just updated and getting same error code as Newbie. Invalid pointer operation. Access violation at address 006E970D in module Wisecare.365.Read of address 0000002C. I am also running Win 7 Home premium 64 bit .Service pack1 Tried uninstalling Wise Care 365 and re-installing. Getting same error code.
VVayOutVVest Posted May 14, 2014 Report Posted May 14, 2014 I have the same issue with the same error messages as the above posters, as a result Wise Care 365 pro has become unusable for me.
VVayOutVVest Posted May 14, 2014 Report Posted May 14, 2014 Attached is a screenshot of the error message that appears whenever I press the Check Up Now button.
xilolee Posted May 14, 2014 Report Posted May 14, 2014 Hi guys. Are you all using Windows 7 x64? Are you all using Wise Cleaner 365 PRO 2.98.243? Installer or portable? Anyway, today there's a new version (2.99.254). VVayOutVVest 1
bigkid1950 Posted May 14, 2014 Report Posted May 14, 2014 Yes, I am. WiseCare365 Pro, Win 7 x64, Service pack 1 Using Google Chrome, SeaMonkey, IE10 and sometimes Firefox browsers. Ran perfectly until it updated. It kept my machine running like a top. I run it daily... at least, I did. Any help would be greatly appreciated. Tried uninstall and reinstall. Same error code.
bigkid1950 Posted May 14, 2014 Report Posted May 14, 2014 Used CCleaner to uninstall Wise Care 365pRO 2.98.243. That found 3 files that weren't previously uninstalled. Downloaded 2.99 and it is now working properly . THANK YOU for your help. Yes!!! Shut system down, Ran Wise Care on start-up. Everything seems to be working fine again. Nice to know someone is there to get us out of these messes. Love this software program! VVayOutVVest and bigkid1950 2
VVayOutVVest Posted May 15, 2014 Report Posted May 15, 2014 Thanx xilolee - I'm pleased to confirm that the new 2.99 version fixes the issue I was having and Wise Care 365 Pro is now working normally again. I had to tell 2.98 to update, as it didn't do it automatically and after the update downloaded, I had to use Task Manager to close 2.98, which didn't want to go away. It was a relief to be able to reopen 365 Pro and find 2.99 running with full functionality restored. Cheers to the Wise Care team for the prompt response and fix. bigkid1950 1
xilolee Posted May 15, 2014 Report Posted May 15, 2014 Wise Developers are quick! Thanks to them bigkid1950 and VVayOutVVest 2
