saad Posted January 29, 2014 Report Posted January 29, 2014 Advanced Cleaner didn't remove empty Start Menu folders after removing the invalid shortcuts.
UCanFixIt Posted January 29, 2014 Report Posted January 29, 2014 I am not aware that it is intended to also remove empty folders when searching for (and removing) invalid shortcuts. My assumption was that the shortcut would be invalid because it pointed to an empty folder but the empty folder would remain. Can someone from Wise confirm my conclusions?
WiseCleaner Posted February 7, 2014 Report Posted February 7, 2014 Hi saad, This function is in Common Cleaner, not Advanced Cleaner.
saad Posted February 9, 2014 Author Report Posted February 9, 2014 Hi saad, This function is in Common Cleaner, not Advanced Cleaner. 3.jpg It is accessible through Advanced Cleaner also!
xilolee Posted February 9, 2014 Report Posted February 9, 2014 I.e., after you cleaned the invalid shortcuts through Advanced Cleaner, do you run the common cleaner - invalid start menues, clean them, but they are not cleaned?
saad Posted February 11, 2014 Author Report Posted February 11, 2014 I.e., after you cleaned the invalid shortcuts through Advanced Cleaner, do you run the common cleaner - invalid start menues, clean them, but they are not cleaned? I tried that too before I post the issue. By the way, you need to know the program a little more!
wisecleaner_admin Posted February 12, 2014 Report Posted February 12, 2014 Hi saad, Sorry for reply you late. I understand your meaning, let me explain it. Advanced Cleaner, it will scan all drives of yours (C: & D: & E: ...) , just remove Invalid Shortcuts, not include its folder. (remove its folder is very dangerous, we don't know the folder whether contain other files.) Common Cleaner, it will scan C: drive, remove Invalid Start Menu, include invalid shortcuts and folder. Do you understand? UCanFixIt 1
