jdeek07 Posted July 11, 2016 Report Posted July 11, 2016 Hello, I have a question regarding video conversion from mp4 to wmv format. I successfully converted the video I was intending to the format listed above, however, during the conversion process, it re-arranged the video from being upright (vertical; as it was originally shot) to now being sideways (horizontal; converted by Wise). I'm having difficulty deciphering why this is happening as the video was not shot like this or why its converting it like this when I didn't change anything in the settings. I can't seem to find any settings to alter this either. Can someone please explain why this is happening or how to fix this if possible. It makes the rendering of a conversion unimportant otherwise if I can't maintain the integrity of the how the video was originally captured. Thanks for any and all assistance provided! Yourdob 1
xilolee Posted July 11, 2016 Report Posted July 11, 2016 Hi jdeek07. I don't know if in this forum you can get help about that software... By the way, I think you should provide some basic informations about your system configuration (exact OS, gpu, cpu, motherboard, software used: wisevideoconverter fre or pro? Or other?, what version? And so forth...). The official email to get help should be: support AT wisevideosuite DOT com Hope this helps!
jdeek07 Posted July 11, 2016 Author Report Posted July 11, 2016 Hi jdeek07. I don't know if in this forum you can get help about that software... By the way, I think you should provide some basic informations about your system configuration (exact OS, gpu, cpu, motherboard, software used: wisevideoconverter fre or pro? Or other?, what version? And so forth...). The official email to get help should be: support AT wisevideosuite DOT com Hope this helps! Thanks for the reply! I did try to email support at that email address and received no reply back from them which is why I took this issue here. When I clicked on the program settings, it sent me here as the forum to use as a support system so I assumed I was in the correct place. Here are the specs on my rig, maybe you or someone else can assist...Windows 7 Pro, AMD A6 4400 w/ 2.7GHz, 16GB RAM. I'm using Wise Video Converter (free version; possibly this setting option is only available in pro), and according to the program, I'm using the current updated version of 1.51 Hopefully you know the answer to this or can redirect this to where it belongs, possibly someone with system knowledge of the program itself. Thanks again!!
xilolee Posted July 12, 2016 Report Posted July 12, 2016 I installed it, then "portabilized" it, and converted an MP4 to WMV: it worked in the correct manner. The size was doubled... I think you should wait a more authoritative answer than mine.
wisecleaner_admin Posted July 14, 2016 Report Posted July 14, 2016 Hey Jdeek07, Actually, we have replyed you in July 12th, please check your spam box and inbox. Can you tell me your video's properties, e.g., Frame width and Frame height, a screenshot is good. Thanks.
