xilolee Posted April 4, 2014 Report Share Posted April 4, 2014 Translations for the new log Following is the Italian translation: [Translation] LangCode=0410 FrmMain.btnLog.Caption=Registro TfrmUnlog.caption=Registro di disinstallazione TfrmUnlog.head.unDate=Data di disinstallazione TfrmUnlog.head.ItemName=Oggetti disinstallati TfrmUnlog.head.restore=Oggetti rimasti TfrmUnlog.noItems=Nessun oggetto rimasto TfrmUnlog.Recovered=Recuperato TfrmUnlog.recover=Recupera ReadHabit=Left-to-right Judsonclouh, BoxTriaxia, Williamtak and 5 others 8 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 8, 2014 Report Share Posted April 8, 2014 Thanks xilolee! Link to comment Share on other sites More sharing options...
abcdefgh Posted November 4, 2014 Report Share Posted November 4, 2014 Hello, a few weeks ago i downloaded WPU & start using it, love it.... yeah After using it for a while, i had a few problem, finally fixed it... in that time got some ideas what could be done to improve it. Suggestions: + add BACKUP & RESTORE buttons + before UNINSTALLING the program - BACKUP should be done AUTOMATICAL + add SETTINGS button + would be nice, if i could change SKIN / COLOR + how come there is no regular updates? http://www.wisecleaner.com/blog_sort_11.html AppeptGause, Israeltric, SallyEa and 1 other 4 Link to comment Share on other sites More sharing options...
abcdefgh Posted November 6, 2014 Report Share Posted November 6, 2014 Why i CANT REPAIR / MODIFY bitdefender from WPU, but i CAN from windows? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 7, 2014 Report Share Posted November 7, 2014 About your suggestions: + add BACKUP & RESTORE buttons Before we released the first version of WPU, we have considered this Backup/Restore feature. But finally we didn't add it. How to back up before uninstall a program? Back up all files? It will costs more time and disk space. Create a System Restore point? If user stops Windows System Protection, we can not create a restore point. If user install a program in a non-system drive, system restore point cannot restore the program. We know, Windows can not keep unlimited system restore point records, depends on the system drive space, when the records over the limitation, the earliest record (the first one system restore point record) will be removed. So, we add the uninstallation Log feature, you can know those be uninstalled programs, and you can re-install them by yourself. + add SETTINGS button Which settings do you want us to add? I think WPU is very easy to use. No need additional settings. + would be nice, if i could change SKIN / COLOR Change color, maybe we can add it. About modify Bitdefender, we will test it and fix it in next update. Link to comment Share on other sites More sharing options...
abcdefgh Posted November 7, 2014 Report Share Posted November 7, 2014 Thank You for your Quick reply UNINSTALLATION LOG You cant allways re-install programs because NO RESIDUAL ITEMS is displayed. That why i suggest BACKUP button like WRC has it. Whit 1 click, program should make FULL REGISTRY BACK UP & SYSTEM RESTORE POINT (if system restore point is DISABLED in win, the pop out windows should ask if you wanna ANABLE IT?, same like in WDC, if you click NO then just Registry backup is made). I like WPU very much, but its annoying that i have to open WRC first to make BACKUPS, then open WPU and uninstal the program. I did use once re-install option in WPU from Log & had a big problems. WPU "reinstalled" programs that where NEVER DELETED (pic. 1 - 5) Needed 1 day to fix the PC. SETTINGS BUTTON if posible to add a "click" option on AUTO BACK UP Full Registry before cleaning & AUTO BACK UP System Restore Point, like WRC has it. You can safely choose what the WPU will AUTO backup before you uninstall anything. I think this is very nice & easy option without of aditional clicking. (my idea is: i open WPU & uninstall any program (WPU makes AUTO backups before my uninstallation), i close WPU. If something is wrong & not working, i open WPU and use RESTORE button. Link to comment Share on other sites More sharing options...
abcdefgh Posted November 7, 2014 Report Share Posted November 7, 2014 After i did REPAIR INSTALATION on Bitdefender AV on 11/6/2014, WPU shows WRONG / OLD instalation date 11/5/2014. Link to comment Share on other sites More sharing options...
abcdefgh Posted November 10, 2014 Report Share Posted November 10, 2014 WPU 1.64 DELETED Adobe Flash Player & part of NeXus Program while Uninstalling MSXML 4.0 SP3 Parser & using Safe Uninstall option. PS: i Also needed 2 WIN UPDATES (KB2972216 & KB2894854), .NET Framework 4.5, 4.5.1 - was deleted or damaged - dont know exactly!!! PPS: PLEASE add AUTO BACKUP option for Registry & System Restore Point, before uninstalling begins!!! This is the 2nd time now, that i have to install damaged Programs all over again & try to fix WPUs damage. Link to comment Share on other sites More sharing options...
abcdefgh Posted November 10, 2014 Report Share Posted November 10, 2014 WPU 1.64 does NOT writes Logs for Uninstalled Microsoft Visual C++ Link to comment Share on other sites More sharing options...
abcdefgh Posted November 10, 2014 Report Share Posted November 10, 2014 WPU 1.64 from time to time "Freezes / Stop Working" - Only dash is blinking in search box. Wont exept clicking with mouse pointer! Hm... Have PRT SC but there is nothing to see! Link to comment Share on other sites More sharing options...
threichert Posted January 11, 2015 Report Share Posted January 11, 2015 Any way of adding a feature to show or not show Security and Windows Updates? It would be highly unlikely that anyone would uninstall them and it takes quite a bit of space up that you have to scroll though. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 12, 2015 Report Share Posted January 12, 2015 @threichert Thank you for your suggestion. Link to comment Share on other sites More sharing options...
Methavas Posted April 18, 2015 Report Share Posted April 18, 2015 Good evening, I would suggest a feature for WPU: can you add the possibility to uninstall multiple applications (or updates)? I have to uninstall 50 updates and now I have to do it manually for each entry. It would be nice if you can select all entries you want and then the program uninstall them automatically, one by one. Thanks Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted April 20, 2015 Report Share Posted April 20, 2015 @Methavas, Thank you for your suggestion. Windows system doesn't support it, programs should be uninstalled one by one. But I will reported it to our developer team, maybe they have some good ideas. Link to comment Share on other sites More sharing options...
geonetor Posted September 17, 2015 Report Share Posted September 17, 2015 Hello Please add an option to start with the programs list sorted by date/size/name. Thank you. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 23, 2015 Report Share Posted September 23, 2015 @geonetor, Thanks for your suggestion. Current version of wise program uninstaller, you can sort the list like you said, just need to click the title Date/Size/Name Link to comment Share on other sites More sharing options...
xANDYx Posted December 19, 2015 Report Share Posted December 19, 2015 Hi ive been using WPU,and I got the popup to upgrade to a newer version,when I click the download its not doing anything a tab opens and its blank,tried 3 diferent browsers and its the same with all of them please help Link to comment Share on other sites More sharing options...
xilolee Posted December 20, 2015 Author Report Share Posted December 20, 2015 Hi xAndyx. Are you trying to update from v1.82 to v1.83, directly from the program? Or are you using the browser, from WiseCleaner download center (click)? The three links (about WPU) on it are working, at least now. If they don't work for you: what firewall and what antivirus are you using? Link to comment Share on other sites More sharing options...
borut Posted January 7, 2016 Report Share Posted January 7, 2016 The program does not always removes empty folders after uninstalling. When installing multiple programs leave empty folders.A competitive program "BCUninstaller" removes properly. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 8, 2016 Report Share Posted January 8, 2016 Hey borut, Thanks, Can you tell me which program's empty folder not be removed after uninstalling? Name and version, we will check it. Link to comment Share on other sites More sharing options...
borut Posted January 8, 2016 Report Share Posted January 8, 2016 Now I have uninstalled your program, but how to install again, this reply. Jabzooge, Stevenjek, pherhealf and 4 others 7 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 8, 2016 Report Share Posted January 8, 2016 Hey borut, You can download wise program uninstaller by clicking this link: www.wisecleaner.com/soft/WPUSetup.exe You said, 'when uninstall multiple programs leave empty folders', so, I want to know those empty folders belong to which programs. If you don't remember the name, never mind. Next time, when you use WPU to uninstall a program, but don't remove the program's folder, please notice to us. We will check and improve WPU. Thanks. Link to comment Share on other sites More sharing options...
borut Posted January 8, 2016 Report Share Posted January 8, 2016 After uninstall Iperius Backup Free: http://www.iperiusbackup.com/ It remained a program folder in the folder "C:\\ProgramData" Link to comment Share on other sites More sharing options...
doggie007 Posted January 10, 2016 Report Share Posted January 10, 2016 Hello !! Wise Program Uninstaller. I really-really like this product! I will me writing about it here. Merry-Merry Christmas and a happy new year, 2016! Hugs. Link to comment Share on other sites More sharing options...
doggie007 Posted January 10, 2016 Report Share Posted January 10, 2016 Hi ive been using WPU,and I got the popup to upgrade to a newer version,when I click the download its not doing anything a tab opens and its blank,tried 3 diferent browsers and its the same with all of them please help Maybe the update isn't available yet, if the page is blank (it's usual). Link to comment Share on other sites More sharing options...
