pete Posted September 1, 2014 Report Share Posted September 1, 2014 Can't run the program after clicking the desktop icon. A menu said the following: "Skype.exe - Application Error The instruction at "0x005ada10" referenced memory at "0x78e8a36c". The memory could not be "read". Click on OK to terminate the program Click on CANCEL to debug the program" And no response if I click on either buttons! Do you know what that's means, aside from a corrupted windowsXP operating program, thanks! Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: D:\WINDOWS2 Available physical memory: 991 MB CPU: AMD Athlon XP Drive Info: C: 37.26 GB D: 54.40 GB E: 55.59 GB Internet Explorer: 7.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 3, 2014 Report Share Posted September 3, 2014 Do you have installed two OS? Make sure you installed Skype on Windows xp. If not, reinstall Skype may fix this issue Link to comment Share on other sites More sharing options...
xilolee Posted September 4, 2014 Report Share Posted September 4, 2014 Minimum requirements for Skype: WinXP SP3, 1GHz processor, 512MB RAM, directx 9 How to determine the version of DirectX by using the DirectX Diagnostic Tool Link to comment Share on other sites More sharing options...
