seidedick Posted August 21, 2014 Report Share Posted August 21, 2014 runtime error 429 Activex component can't create objecty Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 5941 MB CPU: Intel® Core i5 CPU 650 @ 3.20GHz Drive Info: C: 451.17 GB D: 496.08 GB J: 451.17 GB K: 464.59 GB M: 1863.01 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted August 22, 2014 Report Share Posted August 22, 2014 Show me a screenshot of the error message. Link to comment Share on other sites More sharing options...
xilolee Posted September 2, 2014 Report Share Posted September 2, 2014 From CreateObject Function (Visual Basic) Exception 429: - ProgId not found or not supplied OR - ServerName fails the DnsValidateName function, most likely because it is longer than 63 characters or contains an invalid character. Check also Cannot create ActiveX Component Someone else says that you can try to repair your office installation (through control panel, programs, office, repair). If those hints don't help to solve the problem, we need more informations, like: What MS office version are you using? Are you trying to program in visual basic or in VBA? Are you using a program already compiled/done? Link to comment Share on other sites More sharing options...
