Posted
I have just used Registry Cleaner and lost all my bookmarks. This is the second time that this has happened, the first time was with 365. Last time, I managed to recover them from the Library, but this time I can't. Can any one tell me if this is a glitch, and also if it's possible to back up my bookmarks as I go along?
Thanks in advance.
0liver
Posted
Hello again Oliver,
Since you did not identify your browser, my advice is limited to just advising you to backup (eg, export your bookmarks) before attempting another run of WRC. This will allow for easy recovery of same (eg, import your bookmarks) in case you encounter this issue again. I would also advise you to run WRC in the "normal" mode (not deep scan mode) with all settings at default.
UCanFixit
Posted
Go to the browser histroy and find the details from the browser histroy. Press Ctrl + H and go the folder according to date and view it. you will find your Wise Registry Cleaner backup from the browser. if you need simple option to find Wise Registry Cleaner backup.
