Posted
Dobrý den,
nezobrazuje se historie prohlížení v IE11.Vyzkoušel jsem všechno možné, včetně přeinstalace IE, ale problém přetrvává.Jiné prohlížeče historii zobrazují. Díky.
System root: C:\Windows
Available physical memory: 3835 MB
CPU: AMD Athlon II P320 Dual-Core Processor
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
Internet Explorer: 11.0
Posted
translated from czech
IE browsing history
Hello, does not appear in the browsing history in IE11.
I've tried everything, including reinstalling IE, but the problem persists.
Other browsers show the history.
Thank you.
Tools, internet options, advanced tab, reset (Windows needs to be restarted).
Posted
Dobrý den, reset prohlížeče také nepomohl, zřejmě bude nutné obnovit celé Windows do původního nastavení. Nejstarší bod obnovení v seznamu je z června tohoto roku , i když počítač je 4 roky starý??. Také to nepomohlo, díky.
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
Posted
Hello, reset the browser also does not work, you may need to restore the entire Windows to its original settings.
The oldest restore point in the list is from June this year, even if the computer is four years old?
It also did not help, thanks.
How do you start IE 11? Double click desktop shortcut or task bar icon?
If yes, please right click on the shortcut, click Properties->Shortcut->Target, the correct value is "C:\Program Files\Internet Explorer\iexplore.exe"
If it doesn't work, please open Control Panel->Uninstall a program->View installed updates, find out Windows Internet Explorer 11, then uninstall it.
The IE 11 will roll back to IE 10. Then try again, whether it has browsing history
Posted
I'm not using the history, but I get this on mine:
I can't view the history on the left panel, but I can view it clicking the button on the address bar.
Is it the same for you?
Posted
Dobrý den,
přeinstalace IE11 také nepomohla, nezobrazuje se ani v IE10.
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
Posted
Nějak nevím ,co s tím.
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
Posted
1) Click start, type in the searchbox
cmd
press enter: you should see a black command prompt window
Note: the command prompt could be non-elevated (unelevated?), i.e. it could be run without elevation
2) Type/copy (in the command prompt)
cd /d C:\Users\%username%\AppData\Local\Microsoft\Windows
(and press enter)
3) Type/copy
attrib history +s
(and press enter)
4) Problem solved (it worked for my MSIE11, i.e. I can now see the history)
Credits to: jeepee73's answer, but he gave the credits to computermensch's answer
Posted
Dostávám odpověď - soubor nebyl nalezen (attrib history +s) -
I get the answer - file not found (attrib history +s) -
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
Posted
Dobrý den, už je to v pořádku, historie se opět zobrazuje. Díky moc!
Hello, it's alright, history is again displayed. Thanks a lot!
Posted
Dobrý den, problém s historií prohlížení byl vyřešen, ale je tu ještě problém s informačními kanály. Podobně jako to bylo u historie se zde také nic nezobrazuje. Díky
Nezobrazují se také informační kanály. Jak to můžu opravit? díky
Hello, problem with browsing history has been resolved, but there is a problem with the feed. Like it was in history is also blank. thanks
Unable to see also feeds. How can I fix this? Thanks
Do not appear to feeds. Thanks
Posted
translated from czech: Unable to see also feeds. How can I fix this? Thanks
Try the same command, but with feeds; open a command prompt, then type (or copy) in it:
cd /d C:\Users\%username%\AppData\Local\Microsoft (press enter key on your keyboard)
attrib feeds +s (press enter key on your keyboard)
Posted
Open a command prompt, then type/copy:
(press enter)
attrib feeds -s
(press enter)
attrib "feeds cache" +h +s
(press enter)
Posted
Hello,
do not diplay RSS feeds, thanks.
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
Posted
Yes, tried.
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
Posted
No error message,the field RSS feeds is empty( in the top right next to history).
C: 284,51 GB
D: 13,28 GB
E: 0,10 GB
