aish Posted June 28, 2014 Report Posted June 28, 2014 a widow is comig says ur file is corrupted....get aother copy of applicatio can't install wisecleaner 365 to my lap Operating system:Windows 8 Single Language (64 bit) System root: C:\Windows Available physical memory: 3988 MB CPU: Intel® Core i3-3110M CPU @ 2.40GHz Drive Info: C: 448.28 GB D: 16.71 GB Internet Explorer: 10.0 mrpj2u 1
xilolee Posted July 1, 2014 Report Posted July 1, 2014 Download the installer from here (click), or try the portable version.
mrpj2u Posted July 2, 2014 Report Posted July 2, 2014 Hi Can I ask what the difference is between the standard executable installer & the portable version? (apart from the fact that it does not need to be installed & can be copied to portable media for use) For example is there any difference in functionality and can the portable version be registered. If the portable version is installed and registered for use on the same computer (eg disaster recovery) Does that count as a seperate installation & is a seperate licence required (I bought a licence for 3 pc's) Regards MrPj57 mrpj2u 1
wisecleaner_admin Posted July 3, 2014 Report Posted July 3, 2014 @MrPj57, The difference is you can store portable version in removable device and run it in other computer without installation. But, when you activate wise care 365, the license key will be stored in your local system, the portable version won't contain the license key. It means, if other computer has not installed a license key, the portable version is a free version. A license for 3 PCs, means this license can be stored in 3 computers, no matter the wise care 365 is portable version or an installed version.
xilolee Posted July 3, 2014 Report Posted July 3, 2014 can the portable version be registered. Mine is registered and I'm using the portable one.
