Radif Posted March 30, 2014 Report Share Posted March 30, 2014 Купил ноутбук toshiba satellite на нём стоял windows 8 потом произошла проблем он начал перезагружаться... После этого я переустановил Windows и проблема исчезла, но возникла другая. У меня стал тормазить комп... открываю диспейтчер задач а там загрузка ЦП-100% и Диск-100%. Что мне делать? Operating system:Windows 8 Single Language (64 bit) System root: C:\windows Available physical memory: 4047 MB CPU: Intel® Core i5-3210M CPU @ 2.50GHz Drive Info: C: 458,24 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 31, 2014 Report Share Posted March 31, 2014 Sorry, I cannot understand you. Google Translate can not translate your words to English. Link to comment Share on other sites More sharing options...
xilolee Posted April 1, 2014 Report Share Posted April 1, 2014 Translated from belarusian: Overloaded CPU 100% and 100% Disc Bought a laptop toshiba satellite it was windows 8 problems occurred then he started to reboot ... Then I reinstalled Windows and the problem disappeared, but there was another. I became a computer slows down ... open dispeytcher tasks and there CPU 100% and 100% Disc. What do I do? Hi radif! Your screenshot shows 98% on the disk, but doesn't show which program/application causes it. If possible, find and show it. If the warranty has expired, you could try to open your PC with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor. Looking forward for your kind feedback. Link to comment Share on other sites More sharing options...
