colincallan Posted March 23, 2014 Report Posted March 23, 2014 This window keeps popping up every 5 minutes even though I have clicked on the "DONT ASK ABOUT THIS PROBLEM AGAIN (NOT RECOMMENDED)" option. It can't be the hard drive surely, the laptop isn't old enough surely? Nor had a lot of use! Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3835 MB CPU: AMD Phenom II N660 Dual-Core Processor Drive Info: C: 465.66 GB Internet Explorer: 11.0
wisecleaner_admin Posted March 24, 2014 Report Posted March 24, 2014 According to this pop-up message, it seems your hard disk has bad sector or other problems. You can try this way to fix this problem. Right click drive C--> Properties-->Tools-->Error-checking-->Check now, check Scan for and attempt recovery of bad sectors. Start it. If you still get this message, click Show details, and send to us.
colincallan Posted March 24, 2014 Author Report Posted March 24, 2014 Hello I have another screenprint of MSE showing that Virus:DOS/Rovnix.V has been detected but not found. How can this be? Surely if it has been detected then it can be found? Problem is this, I cannot upload the jpeg. Pulling my hair out now!
xilolee Posted March 24, 2014 Report Posted March 24, 2014 Download/run these programs: Full scan with your antivirus adwcleaner (click) Junkware removal tool (click) superantispyware free (click) sophos virus removal tool free (click) MBAM free (click) stinger 32 bit (click) or stinger 64 bit (click) (according to your windows BIT version) MS Safety Scanner 32 bit (click) or MS Safety Scanner 64 bit (click) (according to your windows BIT version)
wisecleaner_admin Posted March 25, 2014 Report Posted March 25, 2014 If you cannot remove DOS/Rovnix.V by xilolee's suggestion, you can try others suggestion from Internet. Manual remove: 1. How to stop Virus: DOS/Rovnix.V processes: 1). Click the Start menu, select Run. 2). Type taskmgr.exe into the the Run command box, and click “OK.” You can also launch the Task Manager by pressing keys CTRL + Shift + ESC. 3). Click Processes tab, and find Virus: DOS/Rovnix.V related processes. 4). Once you’ve found the Virus: DOS/Rovnix.V related processes, right-click them and select “End Process” to kill Virus: DOS/Rovnix.V related process. 2. With all programs closed, click the Start Menu and go to the Control Panel. 1). Locate the Add/Remove Programs icon and double click it. 2). Locate Virus: DOS/Rovnix.V in the list of programs. If you find it, select it and remove it. 3. Detect and delete Virus: DOS/Rovnix.V associated files listed below: %UserProfile%\Application Data\Microsoft\[random].exe %System Root%\Samples %User Profile%\Local Settings\Temp %Documents and Settings%\All Users\Start Menu\Programs\Virus: DOS/Rovnix.V %Documents and Settings%\All Users\Application Data\Virus: DOS/Rovnix.V doguzeri.dll 3948550101.exe 3948550101.cfg %Program Files%\Virus: DOS/Rovnix.V %Program Files%\Virus: DOS/Rovnix.V C:\ProgramData\[random numbers]\ 4. How to delete Virus: DOS/Rovnix.V files in Windows XP/Vista/7: 1). Click your Windows Start menu, then click “Search.” 2). A pop up will ask, “What do you want to search for?” Click “All files and folders.” 3). Type a Virus: DOS/Rovnix.V file in the search box, and select “Local Hard Drives.” 4). Click “Search.” Once the Virus: DOS/Rovnix.V file is found, delete it. 5. Open the Registry Editor, search and delete these Virus: DOS/Rovnix.V Registry Entries: Before you remove registry items, please create a registry backup. You can run Wise Registry Cleaner to backup registry. HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msmpeng.exe “Debugger” = ‘svchost.exe’ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msseces.exe “Debugger” = ‘svchost.exe’ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Virus: DOS/Rovnix.V HKEY_LOCAL_MACHINE\SOFTWARE\Virus: DOS/Rovnix.V HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings “WarnOnHTTPSToHTTPRedirect” = ’0′ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Internet Settings “WarnOnHTTPSToHTTPRedirect” = ’0′ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SystemRestore “DisableSR ” = ’1′ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\ekrn.exe “Debugger” = ‘svchost.exe’ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\msascui.exe “Debugger” = ‘svchost.exe’ HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run “3948550101″ HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run “xas” HKEY_CURRENT_USER\Software\Virus: DOS/Rovnix.V Please, be informed that manual removal of Virus: DOS/Rovnix.V virus is a cumbersome procedure and does not always ensure complete deletion of the Virus: DOS/Rovnix.V, since some files might be hidden or may automatically reanimate themselves later.
alexwaston123 Posted January 17, 2021 Report Posted January 17, 2021 Well, you can fix the “Windows detected a hard disk problem” by running the chkdsk command. To do so, try out these steps: · At first, press “Win + R” together to open Run box · Then, type cmd >> hit Enter to open Command Prompt. · Now, type chkdsk C: /f /r /x & hit the Enter. To know more effective ways, refer to http://www.rescuedigitalmedia.com/fix-windows-detected-a-hard-disk-problem
