Posted
Pornire,apoi lucru lent!!!
Operating system:Windows 7 Ultimate (32 bit)
System root: C:\Windows
Available physical memory: 1919 MB
CPU: Intel® Core2 Duo CPU T5550 @ 1.83GHz
C: 232,79 GB
Internet Explorer: 9.0
Posted
Hi ion! :)
1) If the warranty has expired, you could try to open your PC with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor.
2) Open an elevated command prompt and type:
cleanmgr /sageset:65535
Press enter, tick every option inside cleanmgr advanced menu, click ok, then type this:
cleanmgr /sagerun:65535
3) Download adwcleaner portable (click) and run it.
4) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder.
5) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it)
6) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, click fix now.
7) Click the third tab at top: system tuneup
8) Launch sfc /scannow from an elevated command prompt (and report the result here)
9) Defrag your hard disks (it may take hours... Try first the OS partition only).
If you often get BSODs, skip this.
Keep us informed.
  • 2 weeks later...
Posted
laptop too slow!!!!!
C: 232,79 GB
Posted
computer prea lent!!!
C: 232,79 GB
