mesut1946 Posted March 15, 2014 Report Share Posted March 15, 2014 error:incrrect number of parameters in function call. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1527 MB CPU: Intel® Celeron® M CPU 430 @ 1.73GHz Drive Info: C: 48,78 GB D: 7,10 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted March 16, 2014 Report Share Posted March 16, 2014 Hi mesut1946! I think it is not a good program. Remove it from control panel, programs, uninstall a program. Download/run these programs: Full scan with your antivirus adwcleaner (click) Junkware removal tool (click) superantispyware free (click) sophos virus removal tool free (click) MBAM free (click) stinger 32 bit (click) or stinger 64 bit (click) (according to your windows BIT version) MS Safety Scanner 32 bit (click) or MS Safety Scanner 64 bit (click) (according to your windows BIT version) Adwcleaner is usually sufficient to solve the problem (it's fast and easy). Anyway, other scans don't hurt! Keep us informed. Link to comment Share on other sites More sharing options...
mesut1946 Posted March 22, 2014 Author Report Share Posted March 22, 2014 Error;Incorrect number of parameters in function call. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1527 MB CPU: Intel® Celeron® M CPU 430 @ 1.73GHz Drive Info: C: 48,78 GB D: 7,10 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted March 22, 2014 Report Share Posted March 22, 2014 Check your previous topic Link to comment Share on other sites More sharing options...
mesut1946 Posted March 23, 2014 Author Report Share Posted March 23, 2014 yardımınız için teşekkürler. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1527 MB CPU: Intel® Celeron® M CPU 430 @ 1.73GHz Drive Info: C: 48,78 GB D: 7,10 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 24, 2014 Report Share Posted March 24, 2014 You're welcome! Link to comment Share on other sites More sharing options...
xilolee Posted March 24, 2014 Report Share Posted March 24, 2014 Did it work? Link to comment Share on other sites More sharing options...
