stanleycastro01 5 Posted January 22, 2014 Report Share Posted January 22, 2014 Hello I just downloaded wise Disk cleaner last sunday and today I saw in common cleaner that it has a lot of options so can you tell me what should I check? for now I checked all except for Windows Prefetch Data Empty Recycle Bin ( If i check this it will automatically delete files in recycle bin if I clean it right?) Taskbar Jumplists(Please do explain this. When I click the arrow it shows a lot of automatic and custom destinations.) Sun Java(I don't know what this is) Thanks for the help Link to post Share on other sites
UCanFixIt 340 Posted January 23, 2014 Report Share Posted January 23, 2014 Hi, If one doesn't understand the individual options, it is best to run it at the recommended settings (see lower-left of view below). Anyway, to provide additional information regarding your questions: Wise Cleaner will empty the recycle bin if ticked to do so. See here for an explanation of Jump Lists: http://windows.microsoft.com/en-us/windows7/using-jump-lists-to-open-programs-and-items See here for an explanation of Sun Java: http://www.java.com/en/download/faq/whatis_java.xml Good luck! Link to post Share on other sites
stanleycastro01 5 Posted January 24, 2014 Author Report Share Posted January 24, 2014 Oh so sun java is just Java. I thought it's some other kind of Java Iand I noticed that I already have the recommended settings when I installed it maybe i'll just stick with the recommended thanks Link to post Share on other sites
UCanFixIt 340 Posted January 24, 2014 Report Share Posted January 24, 2014 Sounds like a plan to me! Good luck. Link to post Share on other sites
abcdefgh 24 Posted November 6, 2014 Report Share Posted November 6, 2014 Didnt want to open new topic so i will ask here; WDC 8.34.589, how come Advanced Cleaner Tab - ADVANCED SETTINGS are NOT saved when program is reopened / restarted?? Is it a bug or just new setting? How smart is to DELETE empty files from PC? Link to post Share on other sites
wisecleaner_admin 1,340 Posted November 6, 2014 Report Share Posted November 6, 2014 @ASUS Thank you for your feedback. We will fix it in next updates. Link to post Share on other sites
abcdefgh 24 Posted November 6, 2014 Report Share Posted November 6, 2014 How smart is to DELETE empty files from PC? Link to post Share on other sites
wisecleaner_admin 1,340 Posted November 7, 2014 Report Share Posted November 7, 2014 The empty file means its size is 0 byte. Wise Disk Cleaner will search the FAT (File Allocation Table) to find 0 byte files. Link to post Share on other sites
abcdefgh 24 Posted November 7, 2014 Report Share Posted November 7, 2014 abcdefgh 1 Link to post Share on other sites
