Posted
search.snapdo.com/?st=nt&q=
cannot get rid of this
.png
System root: C:\WINDOWS
Available physical memory: 1524 MB
CPU: Intel® Atom CPU N270 @ 1.60GHz
C: 143.20 GB
Internet Explorer: 8.0
  • 2 weeks later...
  • 2 years later...
Posted
Step 1 Remove Snapdo Related Program from Computer
Step 2 Remove Snapdo Related Add-0n and Extensions from your IE browser
Step 3 Change Your browser settings like default search engine and homepage
If you don't know exactly how to perform these steps, go to this detailed removal guide
Posted
Hi, Search.snapdo.com is a browser hijacker that can change you browser homepage and search engine. If you want to remove it completely, you need to clear all its related components from your PC. You can try using a malware removal tool like Malwarebytes to remove it.
  • 4 years later...
