I have Microsoft Windows XP Professional version 2002 Service Pack 3
This is strange because the web cam previously worked on the system. I have uninstalled, clean outed system files many times and tried to re-install it again and it keeps retuning the following error:
RegSvr32 fails to register “C:\Program Files\Creative\Creative WebCam\WebCam Center\CTEffectsFilter.ax
Please how can I resolve this error.
Link to comment
1, check your system for Trojans or viruses. This type of program, in order to modify system control systems often do not responsibly, so as to cause the operating system exception. Common information security awareness should be enhanced, for unidentified executable program must not curious.
2, updating operating systems, operating system installation program copies the correct version of system files, modify system parameters. Sometimes the operating system itself will have a BUG, be aware that installing official release upgrades.
3, try to use the latest official version of the applications, Beta version, the trial version will have a BUG.
4, delete and then re-create the files in the Winnt\System32\Wbem\Repository folder: right-click my computer on the desktop, and then click Manage. In the "services and applications", click Services, and then shut down and stop the Windows Management Instrumentation service. Delete all the files in the Winnt\System32\Wbem\Repository folder. (Please create a backup copy of these files before they are deleted. ) To open the "services and applications", click Services, and then turn on and start the Windows Management Instrumentation service. When the service is restarted, based on the information provided in the following registry key to re-create these files: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\WBEM\CIMOM\Autorecover MOFs
Link to comment
1 I have run scans forTrojans or viruses using avast / Anvi Smart Defender > No threats
2.I have no xp software
3.Doubtful I will upgrade at this point  waiting for next year in  April
4.To Scared that I will miss up the computer
May just buy newer web cam
or will keep searching for answers
any other suggests are appreciated :)
Link to comment
OK ....I looked into the suggestion of stopping and restarting files on windows management Inst.I read the Description for windows management Inst(See Attached files) Says if the service is stopped most windows based software will not function properly ......That sounds like a disaster  :o
Link to comment
The error displays at the same place everytime I try to install the web cam wth the CD
At the 19% of installing the web center.
I get RegSvr32 fails to register “C:\Program Files\Creative\Creative WebCam\WebCam Center\CTEffectsFilter.ax.
I click ok on the error box,it diappears,then the installation moves to 20% & I get the same error message again
I click ok on the error box & it diappears again for the last time
The progress continues wtih the installation of user gudie and then the driver.
On the CD command,I plug in the cam cord into the USB port
The Cam Icon appears on the desktop with web cam light now on.
I open up the web cam,it opens I click on capture and it displays the cam screen.
On the cam screen it says Web camera waiting to plug in.
A message from Microsoft appears(A Box) saying web cam ex. has experienced a problem and must close.
In the BOX there are 2 places to click on
1.  to report problem to Microsoft(Send)  or 2. Don't send
I can click on either choice of the message & the message disappears,then web cam screen closes(disappears).
I failed to mention that this Creative webcam came with
Sound Blaster(audio sound system) and Im not using it now
I can start the cycle again and it will do the same thing...  over and over :(
Link to comment
This is the error message when  I open up the web cam,
I click on the web cam icon
This is the error message that appears after I open up the web cam,
Heres a screenshot of the message
In the white area it would say
Link to comment
Thank u for the driver..... I'll try it
In my first post I wrote
I have Microsoft Windows XP Professional version 2002 Service Pack 3..(I made a error)
That was my old tower that died in Aug of this year>>>this tower has XP service pack 2
Will be installing service pack 3.... shortly
This may be the problem..Will keep u posted
Link to comment
Hi,
You can try following :
1, Download this files http://www.microsoft.com/en-us/download/details.aspx?id=24417
    Reinstall Creative WebCam driver. I suggest you  to this page, mathce your webcame type, download the latest driver.http://support.creative.com/Products/Products.aspx?catid=218
    You said you don't use Sound Blaster now, if you disable it, please enable it first.
2, If step 1 cannot work.
    View this page http://advancedfix.com/windows-exe-files/how-to-fix-cteffectsfilter-ax.html#.UorV6sRkMgI, download the tool try to repair your problem.
3, If step 2 still canot work.
    Seek help from Creative support team. Or view its forum http://forums.creative.com/forumdisplay.php?f=9
Link to comment
CD INSTALLED >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>STEP ONE DONE
I did get the driver installed from the CD finally
Their was a couple of other times that the driver was installed from the CD & working.
So when I would get the error
I would uninstall both the web center and the driver together
The error is still appearing.The web center is not installed & is not in the program population
but the driver is now appearing in the population now
SOUND BLASTER
I cannot reinstall sound blaster because the speakers are in the trash
I'm using a USB sound card with dell speakers
I'll take a look at the forum link Maybe I can get some ideas on how to get around the ERROR
to get the WEB CAM program in the program population with a size #
I'm registered 2 the creative forum
Link to comment
  • 5 months later...
CAN anyone tell me how to unregister these errors ..STEP BY STEP
Please tell me the phrase to enter into Run to unregister
DURING THE INSTALLATION OF THE WEB CAM I GET THESE ERRORS
RegSvr32 fails to register C:\Program Files\Creative\Creative WebCam\WebCam Center\CTFramer grabber
I HAVE  XP / SERVICE PACK 3
Link to comment
Hi joe11.
I see that you have already asked this question, and not only in this forum.
Could you provide the exact steps when you are trying to install the software for your creative webcam nx ultra?
What's the exact model/name of your webcam?
Link to comment
CREATIVE ULTRA LIVE (2002) with CD
Here is the driver that is on the CD software I have & use >>>> 1.0.10.1213
I took the cam - installed the cam - it worked at the end of April 2014 on a another tower at a Community Center just  like the one I have.They gave me one of there towers in 2013
This cam worked on my tower for about 6mts 7/2013 than it stopped working
- still trying 2 reinstall as of today
PLEASE READ CAREFULLY
ERROR Shows up at 24% of the installation
I click OK & it goes away 2nd error shows up at 49% then jumps too 99%
it installs then installs the drive then asks for u to plug in the device
The light goes on the Cam
The icon installs on the desktop.
Once I click on the icon it opens up the cam
The cam is not in the populated in programs
(Revo a Uninstall program I have shows only the driver)
TAKE A LOOK AT THE SCREENSHOTS BELOW
I get these errors ... in order of errors
1st error> I click on> click here I get 2nd error
2nd error I click on...click here I get 3
rd error
the md5 hash is correct.. for Regsvr32 file
I have been told too do these things
1.I have been told I need to reinstall XP
I'm running on admi/my name
No I don't have a XP CD
Finding someone with a XP disc is always possible
2. Unregister and register file
Im searching for instructions on how to
manually unregistered the files then manually re-register them.
 Run CMD
But I don't know the path to type in the black box to unregister
I have tried a couple of combinations - I get not internal - external command
STEPS ON UNREGISTING AND THAN REGISTERING
Need  the full name I will be using to unregister so I can paste in the
Command Prompt.
I USE
CCleaner
Avast
Malwarebytes
Sypbolt
Hitman Pro
Or u may have another idea on how too fix this problem using the tower I have
Your thoughts
Link to comment
ok I have the files  CTEffectsFilter.ax  & CTFramer grabber
ALSO CTVidCap.dll is in  error #2 from screenshot
what do I do with these 2 files ?
I have opened up Properties and see check sum
How do I check the extensions ?
If these 2 files are from the CD and the CD installed a working  cam on another computer....then
what causes RegSvr32 fails to register these too files ???
Link to comment
How to show or hide file name extensions in Windows Explorer
1.Start Windows Explorer, you can do this by opening up any folder.
2.Click Tools, and then click Folder Options.
3.Scroll down and then click Folder and search options.
4.Click the View tab.
5.Scroll down until you notice Hide extensions for known file types, un-check this line by clicking the check box.
Note To hide file name extensions, check this line.
6.Click OK
Check (copy here) the exact filenames (and their extensions), then we'll try to register them.
Link to comment
Hide extensions for known file types was  un-checked
Registering A Filter
  1. Locate the .AX file in question.
    Most of the time these are stored in C:\Windows\System32 or in C:\Program Files\\.
  2. Goto Start>>Run>>Type regsvr32.exe "C:\Location\of the\ax file\filter.ax - Then Hit Enter
  3. It should say it succeeded, if not you likely name to change the path so it is correct.
Pasted
 CTEffectsFilter.ax"
Regsvr32.exe "C:\Program Files\Creative\Creative WebCam Live! Ultra\WebCam Center\ CTEffectsFilter.ax"
CTFramegrabber,ax
regsvr32.exe "C:\Program Files\Creative\Creative WebCam Live! Ultra\WebCam Center \CTFramegrabber.ax"
2 ERRORS APPEAR FOR FILE
1. Load library"C:\Program Files\Creative\Creative WebCam Live! Ultra\WebCamCenter\CTEffectsFilter.ax"
failed.The specific module could not be found
Load library"C:\Program Files\Creative\Creative WebCam Live! Ultra\WebCamCenter\ CTFramegrabber.ax"
2. Dll register server  >>> SEE SCREENSHOT
I copied the location from properties
Link to comment
Try these:
cd "C:\Program Files\Creative\Creative WebCam Live! Ultra\WebCamCenter\"
The following commands should be executed if you are in the previous path:
c:\windows\system32\regsvr32 CTVidCap.dll
c:\windows\system32\regsvr32 CTEffectsFilter.ax
c:\windows\system32\regsvr32 CTFramegrabber.ax
Link to comment
I pasted c:\windows\system32\regsvr32 CTVidCap.dll in run
Got error >>> SEE SCREENSHOT
Load library(
CTVidCap.dll) failed.The specific module could not be found
Get error on each one of the did
I searched
Regsvr32: "LoadLibrary failed - The specified module could not be found"
Heres one of the link
http://www.bpsoftware.com/blog/post/2012/02/25/Regsvr32-LoadLibrary-failed-The-specified-module-could-not-be-found-and-FileMon.aspx
During a recent deployment I had had an issue with the registration of a DLL.  Part of the deployment process included the registration with RegSvr32. On one computer the registration failed with the error “LoadLibrary failed - The specified module could not be found”.  This error was a bit troublesome as the installation process was previously successful on several other computers. I verified the path was correct, the library existed, permissions were correct and more.
I used Process Monitor to trace the activity, filtered on the Regsvr32 process, and noticed that a dependent library was missing. Process Monitor indicated, in the list, the specific file that was not found. In the end I copied the missing library to the computer and the registration was successful.
How do I copy the missing library to the computer and the registration was successful ?
Another answer was
I would suggest downloading the WindowsUpdateAgent30-x86.exe (or WindowsUpdateAgent30-x64.exe for 64-bit systems), and running that command with the/wuforce command line switch.
__________________________________________________________
Can u give me your best ADVICE on how to move forward..
Please try to go step by step on instructions
I will wait for your answers
Link to comment
I forgot to write to try it from the command prompt.
From the run window, type cmd, press enter.
Then launch those commands.
Try these:
Link to comment
I also tried cmd earlier
I'll try it again
....same result ..same error
from the command prompt.....same result ..same error
Im going to focus on the error
Did u read and see under I SEARCH on the my last post ??
I will be researching the above paragraph
I will download  Process Monitor v3.1 and see what it shows
I will let u know once I run the program
what it says.
http://technet.microsoft.com/en-us/sysinternals/bb896645
Link to comment
