nebek 8 Report post Posted March 22, 2014 Hi, this is very nice application so I have some suggestions: 1. to ad an option for weekly shutdown (eg. one day in a week, lets say Sutarday at 17:35) This feature has very few shutdown tools (Aireytec Switch Off) 2. to run whether users are logged on or not 3. to start or not with system start. Regards, Nebojša 8 AppeptGause, LillianJiX, karateMaf and 5 others reacted to this Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted March 25, 2014 Hi nebek, Thank you for your suggestions. 1, Add an option for weekly shutdown. We'll consider it, although only a few people need it. 2, To run whether user is log in or off. It is impossible, if you don't log in, most of third-party programs cannot run. 3, To start with system start If you create a Daily Task, it will start with system start. Share this post Link to post Share on other sites
Zoaky 0 Report post Posted September 3, 2014 Very nice application. Would it be possible to add: Facility to add different shutdown times for different days? - Say you wanted to run an anti-virus scan late on a Friday night. Setup Monthly tasks Edit the text on the shutdown notification Add corpoarate branding Password protect the system tray icon. So users can't cancel or exit the software without knowing the password RegardsZoaky Share this post Link to post Share on other sites
Plagron 0 Report post Posted September 12, 2014 1. Add the autostart program minimized. 2. Add the schedule for the week in the afternoons, for example, Monday - Thursday at the same time Friday, other times and on weekends not included. Share this post Link to post Share on other sites
xilolee 511 Report post Posted September 12, 2014 Newer italian.ini for wise auto shutdown 1.42.70 (I've added .zip to the italian.ini, but it's not really zipped) Italian.ini.zip Share this post Link to post Share on other sites
dalchina 0 Report post Posted November 26, 2014 Hi, hope you don't mind if I suggest some English improvements: 1. Main GUI:Suggestion and feedback->Suggestions and feedbackYour PC will xxxxxx after x hours and..=>Your PC will xxxxxx in x hours and..2. Popup dialogueAre you sure to cancel the current task?=>Are you sure you want to cancel the current task?orDo you really want to cancel the current task?or (short but acceptable)'Really cancel the current task?'Note: I always found my Chinese students making this error. Share this post Link to post Share on other sites
xilolee 511 Report post Posted November 26, 2014 Hi dalchina.Not only chinese students, ì'd say!In italian, we say "Your PC will xxxxxx after x hours and.." = "il tuo pc ... dopo/fra/tra/in x ore e..."Dopo/fra/tra/in = after/between/inUnfortunately, the strings of the english.ini can't be changed, otherwise the program will crash (tried now). We should wait admin/developers! strings to be modified:CancelTask=Are you sure you want to cancel the current task?TaskRunning=The task is running. Are you sure you want to exit?TaskCanceled=The scheduler task was cancelled.ShutdownHint=Your computer will %0:s in %1:s minutes.scheduledfromnow=Your PC will %0:s in %1:s hour(s) and %2:s minute(s).scheduledidle=Your PC will %0:s in %1:s hour(s) and %2:s minute(s) in idle.ReStartNow=Are you sure you want to restart now?ShutdownNow=Are you sure you want to shut down now?NewVer=A new version is available! Do you want to upgrade it now? Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted November 28, 2014 Thank you guys. We will check and modify the language file. Share this post Link to post Share on other sites
Linou 0 Report post Posted December 25, 2014 Hi, and merry Christmas ! I'm using your soft with Window8.1 and I want an hybrid shutdown. Where is it please ? Thanks. Share this post Link to post Share on other sites
xilolee 511 Report post Posted December 25, 2014 What do you mean with "hybrid shutdown"? Share this post Link to post Share on other sites
Linou 0 Report post Posted December 28, 2014 Hi Xilo, This shutdown your computer but prepare it for "quick start" next time. Its correspond to this command: shutdown.exe -s -hybrid -f (for Windows 8 or Windows 8.1 only, hybrid is a new parameter) Share this post Link to post Share on other sites
xilolee 511 Report post Posted December 28, 2014 Hi linou! I don't know if that option actually exists in wise auto shutdown (it seems no).Is yours a feature request?Anyway, the hibernation should be on before that command.I've just tried your command shutdown -s -hybrid -f -t 0 and the hiberfil.sys didn't appear, because I've set it off with powercfg -h off.The WAS hibernate function doesn't work when the hibernation is set to off: it is considered as sleep/standby.Microsoft states that hibernation couldn't be always present: •Video Card: Your video card may not support the sleep function. In this case, update the driver for your video card, or check the video card information and supported drivers that was included with your computer. For more information, see Update drivers: recommended links.•BIOS: Sleep and other power saving states may be turned off in the BIOS of your computer. To turn on the sleep function, restart your computer, and then enter the BIOS setup. When your computer starts, instructions typically appear on the screen to indicate the key or keyboard shortcut that you must press to enter the BIOS setup process. Because not all computer manufacturers use the same BIOS, different keys may be assigned for this purpose.•Windows policies (set from gpedit or regedit by the administrator): Some settings are managed by the system administrator. For more information, see Why won't Windows allow me to change a system setting?•hybrid sleep option turned on (Windows vista and Windows 7). (I didn't understand the last one)Hence, it would be nice whether WAS automatically detect if hibernation is present and/or if hibernation is possible on the current machine.If it is not, it shouldn't show hibernate (and hybrid shutdown, if and when implemented). Or it should automatically enable the hibernation (if the machine supports it)! Share this post Link to post Share on other sites
Linou 0 Report post Posted December 29, 2014 Thanks Xilo, On my computer with an Asus motherboard I didnt change any parameter nor in Win8.1 . And this command works perfectly. I agree mainly with your suggest for next version of WAS. Sorry for my very bad English !! and merry Christmas. French newbie from Paris. Share this post Link to post Share on other sites
Methavas 5 Report post Posted January 29, 2015 Hi, I downloaded this software and I found it very useful. Only a question: wisecleaner_admin said that if you set a Daily task, the program will starts with Windows starts; I set daily shutdown but the program didn't start with system and I have to launch it every day. My version is 1.43.71. What's wrong?? Thanks for the attention, Methavas Share this post Link to post Share on other sites
xilolee 511 Report post Posted January 29, 2015 Check if the Windows task scheduler service is set on automatic and it is started (start-run: services.msc, press enter).It works on my machine win8.1 x64, update1 (I tried restart instead of shutdown).What's your OS?And where did you download WAS from? 1 Methavas reacted to this Share this post Link to post Share on other sites
Methavas 5 Report post Posted January 30, 2015 Hi, today it was started with Windows system.I don't know why yesterday I had to start it manually, but now it seems everything is ok. Thanks for reply, cheers Methavas PS: My OS is Winddows 7 64 bit, I downloaded WAS from Wise website. Share this post Link to post Share on other sites
Methavas 5 Report post Posted February 2, 2015 Hi xilolee, today the program didn't start I checked task scheduler service and i seen that the task was no present in the list; I added it, so I'll see if tomorrow the program starts. Thanks for your help, Methavas Share this post Link to post Share on other sites
Methavas 5 Report post Posted February 3, 2015 I confirm that now all is perfect. The program starts correctly every time the system starts. Thanks for your help xilolee, regards Methavas Share this post Link to post Share on other sites
xilolee 511 Report post Posted February 3, 2015 That's good news! Share this post Link to post Share on other sites
Wisenkind 12 Report post Posted February 10, 2015 Hallo wise cleaner team! Ich mag Wise Auto Shutdown sehr und fänd's prima, wenn er als weitere Option zur festgelegten Zeit (nur) die Internetverbindung trennen kann (solch eine Funktion suche ich schon lange). Besten Gruß! translated from german Hi wise cleaner team! I like Wise Auto Shutdown and very fänd's fine if he (only) can disconnect from the Internet as another option to the set time (such a function I'm looking for a long time). Best regards! 3 Wisenkind, RudyJainy and JosephGefs reacted to this Share this post Link to post Share on other sites
wisecleaner_admin 1,338 Report post Posted February 12, 2015 @Wisenkind, Do you means you want Wise Auto Shutdown to disconnect Internet at a specify time? I will send it to our develop team. Thank you! 1 Wisenkind reacted to this Share this post Link to post Share on other sites
Wisenkind 12 Report post Posted February 12, 2015 Thank you, wisecleaner_admin, that's it :·) Share this post Link to post Share on other sites
Wise_Rider 0 Report post Posted May 6, 2015 Great APP - Lets make it perfect 1. Task activation when NOT LOGGED IN. Being able to set a task to activate when NOT logged in or after reboot before logging in. 2. Count down till task activation. 3. Launch Custom Task. Being able to activated a chosen program with TASK Time parameters. 4. Multiple Task scheduled. Thank U all !!! Share this post Link to post Share on other sites
Nutt 0 Report post Posted May 7, 2015 My PC still shutdown even after I have cancel task, what to do ? Share this post Link to post Share on other sites
