wisecleaner_admin Posted December 25, 2015 Report Share Posted December 25, 2015 (edited) Dear users, Good news here! Wise Registry Cleaner 9 is released the Beta version. Try it now before its official release.Click Here to try WRC 9. You are invited to tell us what you think about it and please have us informed whether anything needs to be modified. Thanks in advance! ****************************** New changes in v9.04, update date: 02-23-2016 1, Fixed the issue in Export report. 2, Improved language displaying ******************************* Hope you like it! Best Regards,WiseCleaner.com Team -------------------------------------------------- Edited February 23, 2016 by wisecleaner_admin Lesterjet, MichaelWeini, JoryikEn and 4 others 7 Link to comment Share on other sites More sharing options...
xilolee Posted December 26, 2015 Report Share Posted December 26, 2015 Hi.It seems WRC has got the same complicated interface of WDC.I'll repeat: honestly I prefer the current interface (WRC 8), because I can use the mouse wheel to scroll the screen.With the new interface, there are a lot of useless clicks!Other con's:- WRC9 is slower (20 seconds to find exactly the same entries)- When exploring the entries, WRC9 doesn't show the tooltips (WRC8 does)- Given the previous point, the double click to expand the column should be mandatory in WRC9Pro's:- The new interface can be expanded to the left/right, even if it is difficult to find the arrow (too small borders?)- Less Chinese ideograms displayed (better Unicode support?)Videos: WRC-differences.zip (click slow download) Link to comment Share on other sites More sharing options...
borut Posted December 26, 2015 Report Share Posted December 26, 2015 My suggestion: Unnecessary function Optimization Tune UP - computer started to go worse. I believe that this function should be only in Wisecare 365. In general, this function does not fit into this type of program. It proposes to add a search engine entries in the registry and replace instead of Tune Up. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 31, 2015 Author Report Share Posted December 31, 2015 Hey xilolee, Thanks, and sorry for the delay. 1, WRC9 is slower (20 seconds to find exactly the same entries) First, WRC8 is using the Default Scan, but WRC9 (the Fast Scan) is using the Safe Scan. we have improved the scan speed, please try the new beta version. 2, When exploring the entries, WRC9 doesn't show the tooltips (WRC8 does) Do you mean this tips? (see the below image) 3, Less Chinese ideograms displayed (better Unicode support?) Can you give me some screenshots? Link to comment Share on other sites More sharing options...
xilolee Posted December 31, 2015 Report Share Posted December 31, 2015 1, WRC9 is slower (20 seconds to find exactly the same entries) First, WRC8 is using the Default Scan, but WRC9 (the Fast Scan) is using the Safe Scan. we have improved the scan speed, please try the new beta version. I have used deep scan with both: same computer and same conditions. Both are portable versions. By the way, improving the speed is always good. Edit 01/01/2016: Tried it now, WRC8 took 2min18s, WRC9 took 2min12s. I found the borders are still too little. 2, When exploring the entries, WRC9 doesn't show the tooltips (WRC8 does) Do you mean this tips? (see the below image) image1.png Yes, I do. 3, Less Chinese ideograms displayed (better Unicode support?) Can you give me some screenshots? Did you see the videos? When WRC8 and WRC9 finish their scans, I open "application paths" in both. You can see the first shows only Chinese ideograms, the second shows also European characters (code page 1252?). By the way: Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 6, 2016 Author Report Share Posted January 6, 2016 Hey xiolee, Thanks. Actually, these unreadable characters neither are Chinese nor other languages. You can click one then click Open in register editor, its type is Reg_Binary, if you double click it, you will see many unreadable characters in the Value data area. So, this is not a display issue of WRC, but we will improve it, just display the key's name without its value. Link to comment Share on other sites More sharing options...
xilolee Posted January 6, 2016 Report Share Posted January 6, 2016 Yes, but something changed in the program because WRC8 didn't read the value, instead WRC9 can read it. That's why I have put it in the PRO's. Another little problem in the new interface, after a scan: when changing language, strings remain with the previous language. When I hover the cursor over them, the language changes. Link to comment Share on other sites More sharing options...
borut Posted January 7, 2016 Report Share Posted January 7, 2016 The program does not check the current beta. After checking the program showed that the current version. After downloading today, the version number was higher. The same is true in Wise Disk Cleaner beta. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 8, 2016 Author Report Share Posted January 8, 2016 Hey borut, Thanks. But, I can't understand you clearly. Do you means (check update) the current version 8.81 can't check out the beta version 9.01? or, what else? Link to comment Share on other sites More sharing options...
borut Posted January 8, 2016 Report Share Posted January 8, 2016 It comes with a beta version 9.01. Yesterday I installed the beta again and i have with the 9.02. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 8, 2016 Author Report Share Posted January 8, 2016 Check for updates is disabled, it will be enabled hen the official version is released. Link to comment Share on other sites More sharing options...
borut Posted January 8, 2016 Report Share Posted January 8, 2016 Too bad. We do not know about changes in the beta versions. Link to comment Share on other sites More sharing options...
borut Posted January 12, 2016 Report Share Posted January 12, 2016 You cannot select some or all of your copies of the "Registry Restore" (selection of the key "CTRL" / "SHIFT"). It should be such an option, or next to the list should be "checkbox", in order to be able to remove multiple copies easily. Currently, you need to delete one by one. Link to comment Share on other sites More sharing options...
doggie007 Posted January 12, 2016 Report Share Posted January 12, 2016 Nice! But why "safe to scan" and deep / advanced are devided? ... safe isn't safe about deep? Link to comment Share on other sites More sharing options...
borut Posted January 13, 2016 Report Share Posted January 13, 2016 Deep scan may delete any needed entries, but not a must. It is best to check what has been detected to be deleted. This program so and so is the best. Does not remove the entries that other programs cause, after erasing the system errors. Link to comment Share on other sites More sharing options...
xilolee Posted January 17, 2016 Report Share Posted January 17, 2016 Hi.Consider also old suggestions here (click).Especially, adding ctrl+click, shift+click, arrows and shift+arrows (on the keyboard) to select entries to be ignored or to be deleted: your competitors have them. Link to comment Share on other sites More sharing options...
borut Posted January 17, 2016 Report Share Posted January 17, 2016 Add global settings/cache "Assistance" in: C:\\Users\\xxxx\\AppData\\Roaming\\Wise Asisstance After the opening WRC 9 and WDC 9 shows the same unread threads help. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 18, 2016 Author Report Share Posted January 18, 2016 Nice! But why "safe to scan" and deep / advanced are devided? ... safe isn't safe about deep? Safe Scan, Only scan and list the safe entries in scan result list. This is recommended. Deep Scan, Scan and list all entries, even though some may not be fully safe to fix. It is for advanced user. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 18, 2016 Author Report Share Posted January 18, 2016 Hey borut, You cannot select some or all of your copies of the "Registry Restore" (selection of the key "CTRL" / "SHIFT"). It should be such an option, or next to the list should be "checkbox", in order to be able to remove multiple copies easily. Currently, you need to delete one by one. We do not advise user to delete registry backup, so, if you want do it, you should delete it one by one. It can avoid accidental deletion all backup. Link to comment Share on other sites More sharing options...
borut Posted January 18, 2016 Report Share Posted January 18, 2016 OK,I understand It so as it is planned the program. Link to comment Share on other sites More sharing options...
xilolee Posted April 5, 2016 Report Share Posted April 5, 2016 Beta period ended. Topic closed and unpinned. DonaldSl, JesseAroto, MichaelWeini and 6 others 9 Link to comment Share on other sites More sharing options...
