xilolee Posted December 5, 2015 Report Share Posted December 5, 2015 Hi guys!I've just noticed there are differences using WCare365-common cleaner, WCare365-PC checkup and WDiskCleaner-common cleaner.I did a scan/clean with the first, and soon after that I did two other scans with the other two functions.It seems WCare365-PC checkup finds more items than WCare365-common cleaner (although they have got the same exclusions).It also seems WDiskCleaner-common cleaner finds more items than WCare365-PC checkup (although they have got the same exclusions... I had to modify WDC exclusions.dat manually, but I did it), and obviously it finds more items then WCare365-common cleaner.I always thought WDiskCleaner was included in WCare365, but this confirm they don't find the same items.I hope to have explained well my doubts.Does it exist an explanation?Is there a method to check what files have been found with WCare365-PC checkup, since they appear after common cleaner has been used?I noticed they are 10, and I excluded 10 files: does WCare365-PC checkup skip the exclusions I made (carefully)?Thanks in advance. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 10, 2015 Report Share Posted December 10, 2015 Thanks xilolee. I only find one item - System Log Files, PC-Checkup can find more items than care 365's common cleaner and WDC's common cleaner. You said you have found 10, can you explain them to me? Thanks. Ivan Link to comment Share on other sites More sharing options...
xilolee Posted December 10, 2015 Author Report Share Posted December 10, 2015 I reduced the exclusions to two files. By the way, the results are still different. Video: http://speedy.sh/VnBNW/Wcare365-WDC-differences.zip Link to comment Share on other sites More sharing options...
