ole Posted February 5, 2015 Report Share Posted February 5, 2015 Once in a while the screen suddenly becomes a series of closely spaced horizontal lines and the computer is frozen. Need to reboot at that point.Operating system:Windows 7 Home Premium (64 bit) Service Pack 1System root: C:WindowsAvailable physical memory: 6135 MBCPU: Intel® Core i7 CPU 920 @ 2.67GHzDrive Info:C: 250.00 GBD: 250.00 GBR: 448.59 GBS: 448.60 GBInternet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 8, 2015 Report Share Posted February 8, 2015 Check the following topics: How to speed up your PC by WiseCleaner_Admin How to speed up a computer; speed up any PC or laptop (Part One) by Linkin How to speed up a computer; speed up any PC or laptop (Part Two) by Linkin Or try these operations: 1) If the warranty has expired, you could try to open your PC (first unplug it from the mains...!) with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor. 2) Open an elevated command prompt and type: cleanmgr /sageset:1 Press enter, tick every option (or the options that you prefer) inside cleanmgr advanced menu, click ok, then type this: cleanmgr /sagerun:1Press enter and wait until it finishes. 3) Download adwcleaner portable (click) and run it. 4) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 5) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it) 6) Double left-click wisecare365.exe, click (top right corner) custom --> settings --> custom checkup, select/tick all entries (or the entries that you prefer), click save, click checkup, wait until the scan finishes, click fix. 7) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 8) Launch sfc /scannow from an elevated command prompt (and report the result here) 9) Defrag your hard disks (it may take hours... Try first the OS partition only). If you often get BSODs, skip this. Keep us informed. Link to comment Share on other sites More sharing options...
ole Posted February 8, 2015 Author Report Share Posted February 8, 2015 Thanks. I had already tried all of that. The problem seemed to get worse since posting the above and led to BSOD and restarts. During the last crash there was a message about not being able to start Windows and then a repair (not restore) was performed by Windows. After that I did a Windows repair from the installation disk. So far that seemed to have fixed the problem (a corrupt system file?). Link to comment Share on other sites More sharing options...
xilolee Posted February 8, 2015 Report Share Posted February 8, 2015 Hope it's fixed! Link to comment Share on other sites More sharing options...
