Poncho Posted November 15, 2014 Report Posted November 15, 2014 When I right click on a desktop icon and select 'Delete,' the desktop seemingly pauses, then refreshes, returning with the icon I selected for deletion still remaining and highlighted. Operating system:Windows 8.1 Pro (64 bit) System root: C:WINDOWS Available physical memory: 3560 MB CPU: AMD A6-4400M APU with Radeon HD Graphics Drive Info: C: 465.46 GB F: 0.10 GB Internet Explorer: 11.0
xilolee Posted November 15, 2014 Report Posted November 15, 2014 Hi ponchow.Your screenshot is not visible.You can remove stubborn files through:- unlocker installer (1.9.2) or portable (1.9.0)- superantispyware free (system tools, superdelete file removal OR right-click on the file, superdelete file removal)- malwarebytes FileASSASSIN- hijackthis (2.04 or 2.05beta) (open the misc tools section, delete a file on reboot...) Poncho 1
Poncho Posted November 16, 2014 Author Report Posted November 16, 2014 Thank you. Simple solution. I was too close to the problem.
