abdullah98 Posted November 8, 2014 Report Share Posted November 8, 2014 اذا كنت أبغى أفتح قائمة ستارت في ويندوز 8.1 ما تفتح معاي واذا كنت ابغى افتح برنامج من البرامج حق الويندوز مثل المتجر مايفتح ويطلع لي نافذة مثل التي في الصورة ومكتوب الفئة غير مسجلة . translated from arabic Do not run Windows Features If you i want to open the list of START in Windows 8.1 is open Mai i want and if you open the program right from programs such as Windows Store Mifath and keep my window like that in the picture and written Class not registered. possible english error message (I wasn't able to translate the screenshot, for obvious reasons) Explorer.exe Class not registered. Button: Ok Operating system:Windows 8.1 (64 bit) System root: C:WINDOWS Available physical memory: 3069 MB CPU: Intel® Core2 Duo CPU T6500 @ 2.10GHz Drive Info: C: 97.31 GB D: 200.43 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted November 8, 2014 Report Share Posted November 8, 2014 Use all the tools listed in Free tools (Anti-malware, anti-spyware, anti-virus) that you could use to inspect your computer.Make a complete scan with your antivirus, too.Then, finally, try this command from an elevated command prompt (right-click start, click command prompt (admin)): for %1 in (%windir%\system32\*.dll) do regsvr32.exe /s %1 Link to comment Share on other sites More sharing options...
