hollymusicsmith Posted October 1, 2014 Report Posted October 1, 2014 brand new hp computer older printer installed disc dowloaded drivers and software from internet computer says i need to free up disc space i thought i did but there is not much in computer: it is brand new except what was installed from factory. how do i fix this? i need my multi functional printer it worked fine on windows xp disc said 7 so i dowloaded drivers but it kicks the driver out or not enough space to complete what it needs to operateOperating system:Windows 8.1 (64 bit)System root: C:WINDOWSAvailable physical memory: 3533 MBCPU: AMD A4-5000 APU with Radeon HD GraphicsDrive Info:C: 449.68 GBD: 14.60 GBInternet Explorer: 11.0
UCanFixIt Posted October 2, 2014 Report Posted October 2, 2014 It is hard to believe the manufacturer utilized all your free space so I'm guessing something else has happened. Anyway, show us a screenshot like so: Note that I have a 120GB SSD and I still have 97.7 GBs of free space. It appears you have a 500GB hard drive so I can only assume your manufacturer did not use all that free space. However, if your screenshot reveals that all free space is used, I would go directly to your manufacturer support group or consider an OEM recovery to reset everything to factory defaults.
