Jani Posted May 5, 2014 Report Share Posted May 5, 2014 Javlja napako da ne more odpreti datotek trz4114.tmp in mi jih samo nalaga na računalnik Operating system:Microsoft Windows XP (32 bit) Service Pack 2 System root: C:\WINDOWS Available physical memory: 1918 MB CPU: AMD Athlon 64 X2 Dual Core Processor 4600+ Drive Info: C: 97,65 GB D: 200,43 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted May 6, 2014 Report Share Posted May 6, 2014 translated from slovenian: The fault is Reports error that it can not open the file trz4114.tmp and we just requires a computer Didn't completely understand. You can safely remove .tmp files. Anyway, that filename recalls me some malware and I suggest you to check Free tools (Anti-malware, anti-spyware, anti-virus) that you could use to inspect your computer. Link to comment Share on other sites More sharing options...
