RegSvr32
바이너리가 지정한경로에 저장되었는지 확인하거나 디버그하여 바이너리또는 종속 .DLL 파일에 문제가 있는지 확인하십시오. 지정된 모듈을 찾을수없습니다.
라는 매새지 가 windows 시작하면 뜸.
Operating system:Windows 7 Ultimate (64 bit) Service Pack 1
System root: C:\Windows
Available physical memory: 4092 MB
CPU: AMD Phenom II P920 Quad-Core Processor
C: 172.79 GB
D: 292.97 GB
Internet Explorer: 11.0
Link to comment
translated from korean:
Make sure the binary is stored at the specified path or debug the binary or dependent. DLL files, make sure the problem is. The specified module could not be found.
When you start the windows that leak heat sheets.
  • Press Windows key on your keyboard (and keep it pressed), then press R key, release the two keys (Windows + R), it will open the run window, type SystemPropertiesAdvanced and press enter.
  • Click the environment variables... button (on your screen)
  • Find the path variable and check if c:\windows\system32 (or %SystemRoot%\system32) is present between all the paths
  • If not, add it at the end of the entire string (preceded by a semi colon) and click Always ok.
Link to comment
can you please put in other words to explain?
i don't know what you mean by add "c:\windows\system32" at the end of the entire string (preceded by a semi colon).
what do you mean by entire string? and is semi colon ; or :?
Link to comment
well,
when i go to system variables, i'm greeted with two frames top is administrator variables and bottom is system variable.
neither one contains the regsvr32.exe
does it have to be capitalized? where do i type them in?
Link to comment
Double-left-click This PC on your desktop, double-left-click c:, double-left-click Windows, double-left-click system32, check if RegSvr32.exe is present between other files (you can sort the filenames by clicking ont the name column, if you have set the view to see details - detailed file informations).
Link to comment
And what this question has to do with your original problem?
Anyway, you can usually find which RAMs could be mounted on your motherboard through your motherboard manual.
There is usually a LIST of tested memories on the motherboard website.
Link to comment
