Web Pages slow to load
Hi I'm having troubles with web pages taking extremely long to open or just not opening at all. Anything you can help with?
Operating system:Windows Vista Home Premium (32 bit) Service Pack 2
System root: C:\Windows
Available physical memory: 2039 MB
CPU: Intel® Core2 CPU 6700 @ 2.66GHz
C: 286.61 GB
D: 11.48 GB
F: 219.72 GB
K: 246.04 GB
Internet Explorer: 9.0
Link to comment
Hi brewhuff737! :)
1) Open an elevated command prompt and type:
cleanmgr /sageset:65535
Press enter, tick every option inside cleanmgr advanced menu, click ok, then type this:
cleanmgr /sagerun:65535
2) Download adwcleaner portable (click) and run it.
3) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder.
4) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it)
5) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, click fix now.
6) Click the third tab at top: system tuneup
Keep us informed.
Link to comment
 Share
