eleni Posted February 26, 2014 Report Share Posted February 26, 2014 Internet explorer does not work any also noone browser. Operating system:Windows 7 Ultimate (32 bit) Service Pack 1 System root: C:\Windows Available physical memory: 3060 MB CPU: Intel® Atom CPU D2500 @ 1.86GHz Drive Info: C: 148,95 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 26, 2014 Report Share Posted February 26, 2014 Hi eleni! 1) Download adwcleaner portable (click) and run it. 2) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 3) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it) 4) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, click fix now. 5) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 6) Launch sfc /scannow from an elevated command prompt 7) Defrag your hard disks (it may take hours... Try first the OS partition only). If you often get BSODs, skip this. Keep us informed. UCanFixIt 1 Link to comment Share on other sites More sharing options...
