jeril 0 Posted February 21, 2014 Report Share Posted February 21, 2014 starting error problem Operating system:Windows 8 Pro (64 bit) System root: C:\Windows Available physical memory: 3994 MB CPU: Intel® Core i3-3110M CPU @ 2.40GHz Drive Info: C: 243.80 GB E: 221.62 GB Internet Explorer: 10.0 Link to post Share on other sites
UCanFixIt 339 Posted February 21, 2014 Report Share Posted February 21, 2014 what is the error? David Bailey 1 Link to post Share on other sites
David Bailey 26 Posted February 21, 2014 Report Share Posted February 21, 2014 Use a restore point to go back to before the problem. Since you gave no real info about your problem, Maybe your understanding of computer problems is very limited. In that case, maybe a restore to factory settings would be best. Or maybe not. The more info you provide the better. Especially by posting screenshots of your problems. You have to help us with GOOD information about your problems before we can help you. UCanFixIt 1 Link to post Share on other sites
UCanFixIt 339 Posted February 21, 2014 Report Share Posted February 21, 2014 Use a restore point to go back to before the problem. Since you gave no real info about your problem, Maybe your understanding of computer problems is very limited. In that case, maybe a restore to factory settings would be best. Or maybe not. The more info you provide the better. Especially by posting screenshots of your problems. You have to help us with GOOD information about your problems before we can help you. Diito on that! David Bailey 1 Link to post Share on other sites
xilolee 511 Posted February 22, 2014 Report Share Posted February 22, 2014 Hi jeril! To remove TBupdater.dll, backgroundcontainer.dll, daemonprocess.exe STARTUP errors:1) Remove mobogenie, OpenCandy, Quick Downloader, Conduit.From control panel, programs.2) Download/run these programs:Full scan with your antivirusadwcleaner (click)Junkware removal tool (click)superantispyware free (click)sophos virus removal tool free (click)MBAM free (click)stinger 32 bit (click) or stinger 64 bit (click)(according to your windows BIT version)MS Safety Scanner 32 bit (click) or MS Safety Scanner 64 bit (click)(according to your windows BIT version)Adwcleaner is usually sufficient to solve the problem (it's fast and easy).Anyway, other scans don't hurt! If this is not your problem, read carefully (very carefully) ucanfixit and david bayleys' answers and signs! Keep us informed. David Bailey 1 Link to post Share on other sites
