seashell61 Posted February 7, 2014 Report Posted February 7, 2014 I insert a SD card in my laptop, but Jetsearch cannot recognize it. The SD card is in exFat format. My system is Windows 8. I don't want to convert it into fat32 or NTFS and see if that way works, since is a very large one (64g, nearly full). my portable disk works fine. Please help. Many thanks in advance!
UCanFixIt Posted February 7, 2014 Report Posted February 7, 2014 Hi seashell61,I have just confirmed your finding and I think you have found a legitimate bug! So, I just tested Wise Jet Search and it reacts as follows:SD Card formatted as:NTFS - recognizedexFat - not recognizedHowever, since this is primarily a user-to-user forum, I would suggest you open a bug report (via email) with Wise Support and you can point them to this thread as well:[email protected]Good luck,UCanFixit
WiseCleaner Posted February 7, 2014 Report Posted February 7, 2014 Hi seashell61, Wise Jet Search currently only support NTFS and Fat drive.
UCanFixIt Posted February 7, 2014 Report Posted February 7, 2014 Hi seashell61, Wise Jet Search currently only support NTFS and Fat drive. Hi WiseCleaner, Then please update your description of this program to properly reflect its capabilities:
wisecleaner_admin Posted February 8, 2014 Report Posted February 8, 2014 Thank you very much, UCanFixIt! We have modified the description. UCanFixIt 1
UCanFixIt Posted February 8, 2014 Report Posted February 8, 2014 Thank you very much, UCanFixIt! We have modified the description. Perfect! Now we are all on the same page... Thanks wisecleaner_admin!
