valmick Posted February 3, 2014 Report Share Posted February 3, 2014 takes forever to start up Operating system:Windows Vista Home Premium (32 bit) Service Pack 2 System root: C:\Windows Available physical memory: 2036 MB CPU: Pentium® Dual-Core CPU E5200 @ 2.50GHz Drive Info: C: 222.78 GB D: 9.99 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
UCanFixIt Posted February 3, 2014 Report Share Posted February 3, 2014 See my signature for help in effectively presenting your issue. Link to comment Share on other sites More sharing options...
xilolee Posted February 10, 2014 Report Share Posted February 10, 2014 Hi valmick! You can try: 1) Download adwcleaner portable (click) and run it. 2) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 3) Create a system restore point (or let it create by WiseCare365, it should ask it to you the first time you run it) 4) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, check the results, untick the ones you are not sure to fix, click fix now. 5) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 6) Launch sfc /scannow from an elevated command prompt (and wait that it finishes). If it shows errors, show them here. 7) Defrag your hard disks (it may take hours... Try first the OS partition only). Keep us informed. UCanFixIt 1 Link to comment Share on other sites More sharing options...
