GoldenHands Posted February 1, 2014 Report Posted February 1, 2014 Dear Sir: I was sending a scan file through Windows Outlook. I press send and WiseCare interfered. with sending it. Wasn't able to send it. Why would that happen? Why is WiseCare involved? I have no viruses in the scan file.Please explain how to fix this problem. Sincerely, [email protected] Operating system:Windows Vista Home Premium (64 bit) System root: C:\Windows Available physical memory: 3003 MB CPU: Pentium® Dual-Core CPU T4300 @ 2.10GHz Drive Info: C: 287.17 GB D: 10.92 GB Internet Explorer: 7.0
xilolee Posted February 1, 2014 Report Posted February 1, 2014 Hi goldenhands! Did you solve your previous issue? Could you write exactly what happened (or happens) with wise care? And what wise care version are you using? Free? Pro? Version number? Given that it is not an antivirus or a firewall, I think it should not be involved in your problem.
UCanFixIt Posted February 1, 2014 Report Posted February 1, 2014 Hi goldenhands! Did you solve your previous issue? Could you write exactly what happened (or happens) with wise care? And what wise care version are you using? Free? Pro? Version number? Given that it is not an antivirus or a firewall, I think it should not be involved in your problem. I totally agree with xilolee. So, how do you know it was Wise Care that was interfering? Did you get a message or error that directly relates to Wise Care? If so, post it please.
