NicolasCosta Posted January 28, 2014 Report Posted January 28, 2014 olá, continuo com o erro de quando acesso a página "http://siteprouni.mec.gov.br/" fica carregando e não abre, dizendo que "esta página da web não está disponível" Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 7868 MB CPU: Intel® Core i3-3220 CPU @ 3.30GHz Drive Info: C: 201,99 GB G: 146,48 GB S: 117,19 GB Internet Explorer: 11.0
UCanFixIt Posted January 28, 2014 Report Posted January 28, 2014 Works for me. Have you possibly been banned from that site? If not, your current DNS lookup/routing may be the problem.
NicolasCosta Posted February 4, 2014 Author Report Posted February 4, 2014 i think not, because my other PC's on the same network are ok and have successful to access this site, may be the problem my SO because a try reinstall my browser and continue dont have acess of http://siteprouni.mec.gov.br/ Sorry for my bad english i'm brazilian!!
UCanFixIt Posted February 5, 2014 Report Posted February 5, 2014 i think not, because my other PC's on the same network are ok and have successful to access this site, That's very strange behavior IMHO. Is this the only site that doesn't work? Is there any chance that your IP address is different than the other PCs on the same network (it is possible). Also, have you tried another browser? Finally, can you give us a screenshot of what your failed browser shows when trying to access this site?
NicolasCosta Posted February 5, 2014 Author Report Posted February 5, 2014 no, have more sites doesnt working...all the other pc's are the same IP, i try reinstall the chrome and the operascreenshot here: https://imageshack.com/i/5jwtv7p
UCanFixIt Posted February 5, 2014 Report Posted February 5, 2014 I asked: Is this the only site that doesn't work? You replied: no, have more sites doesnt working... You have other sites that are not working. All of your PCs use the same IP address. You tried both Chrome and Opera (after reinstalling). Is all of the above correct so far? If so, please answer the following questions: Do you use a proxy to access the internet? Are you on a corporate or private network? Are you getting the error message as soon a you try to browse the webpage or after a login attempt at the site in question? Things to try: I know you did a reinstall but make sure your cache and cookies are cleared and try again. FYI, a well designed website is able to differentiate between PCs using the same IP address by using Java code so you could still be blocked via this method. Unfortunately, the language barrier is making it really tough to help. Anyway, please answer my questions and try my suggestions; however, at this point I really think your PC is blocked from accessing that website via a java script that is specifically identifying your PC. I know this can be done because I was an admin (at another forum) and we used that method to identify individuals, that were logging in from different PCs, using the same IP address.
UCanFixIt Posted February 5, 2014 Report Posted February 5, 2014 Here's one more thing to try: Go to this website and enter the URL in question to see if you can access that websire anonymously: http://hideme.be/ It worked for me;
NicolasCosta Posted February 5, 2014 Author Report Posted February 5, 2014 yeah, can be a JS but dont have reason for block me, but ok, im working on a virtual machine and the http://hideme.be/ has sucessfull here, thanks to all and sorry for my bad english...
UCanFixIt Posted February 5, 2014 Report Posted February 5, 2014 im working on a virtual machine Good luck to you. Regards, UCanFixit
