saad 60 Posted January 28, 2014 Report Share Posted January 28, 2014 There should be an option to send the found files to Recycle Bin. Also an option to change wiping algorithm for secure deletion of the files. nohnigefearps74 1 Link to post Share on other sites
wisecleaner_admin 1,340 Posted January 28, 2014 Report Share Posted January 28, 2014 Hi, Thank you. I understand your meaning. 1, Add an option to send the found files to Recycle Bin. We cannot do it. Wise Disk Cleaner has a cleaning item Useless Files In Computer > Windows System > Empty Recycle Bin (we don't set it as recommended.) If someone check this item Empty Recycle Bin, then he click your option Send files to Recycle Bin. What should Wise Disk Cleaner do? 2, An option to change wiping algorithm for secure deletion. I don't think this is necessary. You know, high secure deletion need more times. Less cleaning time is better for cleaning software. Link to post Share on other sites
saad 60 Posted January 28, 2014 Author Report Share Posted January 28, 2014 By the way, how many 'pass' does it use when wiping files? Link to post Share on other sites
wisecleaner_admin 1,340 Posted January 29, 2014 Report Share Posted January 29, 2014 Hi saad, Only "1 pass" If you need more, you can use Disk Eraser in Wise Care 365, it has "i pass", "3 pass", "7 pass" and "35 pass". Link to post Share on other sites
saad 60 Posted January 29, 2014 Author Report Share Posted January 29, 2014 Hi, Thank you. Link to post Share on other sites
UCanFixIt 339 Posted February 5, 2014 Report Share Posted February 5, 2014 Hi saad, Wise Disk Cleaner does have an option for secure deletion of files (see attachment). Also, the send to recycle bin would be a great option if it were technically feasible because it would give one the opportunity to review the actual files before deletion. Now, I would envision that option would work as follows: Send to Recycle Bin if checked Bypass recycle bin if not checked However, I see that our admin has already indicated that it might not be possible to deploy such an option but it was a good suggestion anyway. Cheers! UCanFixit David Bailey 1 Link to post Share on other sites
