eilatoo Posted January 11, 2014 Report Posted January 11, 2014 I have uninstalled, rebooted and reinstalled and rebooted keyscrambler (qfx softwre corporation, version 3.30). However,after installation, when typing online all fields are inappropriately encrypted whereas the program is designed to encrypt only password information and private information For example, if I go to do a search on google, text comes out garbled and then, of course, google doesn't know what to look for. When I typed in "attempt search" on google, I got: "3zux,93sd/\gp7." Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 254 MB CPU: Intel® Pentium® 4 CPU 3.06GHz Drive Info: C: 74.50 GB Internet Explorer: 8.0
xilolee Posted January 11, 2014 Report Posted January 11, 2014 Hi eilatoo! Just to remove all doubts, reset your previous problem to its default setting. Open notepad, copy the following lines into it, save the file as MSIEinstances.reg, double click it and add it to your registry: Windows Registry Editor Version 5.00 [HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main] "TabProcGrowth"=dword:00000001 Then check if MSIE 8 works. Try also rebooting your pc. If this doesn't solve the problem, you can re-use MSIEinstances.reg, modifying 1 to 0. Keep us informed. UCanFixIt 1
eilatoo Posted January 12, 2014 Author Report Posted January 12, 2014 Thank you very much. Your solution worked on the first try.
xilolee Posted January 12, 2014 Report Posted January 12, 2014 In this way your msie8 will open more processes... So this solution excludes the other one (click).
