wisecleaner_admin Posted February 17, 2025 Report Posted February 17, 2025 Since the inception of WiseCleaner, our commitment has always been to provide users with tools that are not only safe, virus-free, and easy to use, but also highly efficient. To ensure compliance with the security standards of various anti-virus programs, we rigorously test each new version by submitting it to Virustotal for a comprehensive security analysis before release. However, due to factors such as updates to the anti-virus software's rules or other unforeseen reasons, Wise Care 365 might be incorrectly flagged as Junkware (PUP): Win32.Application.Agent.12J by G DATA Antivirus (or G DATA Security). This may cause Wise Care 365 to not function, be unable to be reinstalled, or be unable to be updated. If this happens to you, don't worry. We will contact G DATA immediately to correct this false positive as quickly as possible. We also sincerely ask you to submit a false positive report to G Data as a user, which will help us fix this issue quickly. SUBMIT A FALSE POSITIVE TO G DATA In the meantime, you can follow the steps provided below to add Wise Care 365 to the G DATA Antivirus (or G DATA Security) exception list, allowing you to continue using the program without interruption. We deeply appreciate your trust and support for Wisecleaner and thank you for your understanding.
wisecleaner_admin Posted February 17, 2025 Author Report Posted February 17, 2025 Steps to add Wise Care 365 to G DATA Antivirus exclusion list. 1. Open G DATA Antivirus and click the gear icon in the upper right corner to open Settings. 2. Click the Exception button. 3. Click the New button, select Directory, and click the three dots button. Then browse and select C:\Program Files (x86)\Wise If you installed Wise Care 365 to another location, please select it. 4. Click OK to save settings. 5. Back to the main window of G DATA Antivirus, and click the second tab Virus Protection. 6. Click Show Quarantine. 7. Select the record of Wise Care 365, and click the Delete button. 8. Reinstall Wise Care 365.
