Ledminer Posted January 24 Report Share Posted January 24 I have been using WRC for some time using Fast Scan which usually found a few problems and cleaned them. Then tried Deep Scan which found a huge number of which 369 are "unsafe to clean". Most appear in Activex/com and Software paths. Can anything be done about these? Should anything be done? (apart from reloading Windows and starting afresh!) Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 25 Report Share Posted January 25 Hello, "Unsafe" means that Wise Registry Cleaner does not know if it is safe to delete these items, and requires further judgment by the user. If you don't know them either, it is recommended to keep them. r make sure the backup function is enabled, then clean them. Wise Registry Cleaner will backup these registry entries before cleaning. If you have trouble after cleaning, please restore these registry entries from the Restore center. Link to comment Share on other sites More sharing options...
dinaleslie Posted March 16 Report Share Posted March 16 On 1/25/2022 at 12:11 PM, wisecleaner_admin said: Hello, "Unsafe" means that Wise Registry Cleaner does not know if it is safe to delete these items, and requires further judgment by the user. If you don't know them either, it is recommended to keep them. r make sure the backup function is enabled, then clean them. Wise Registry Cleaner will backup these registry entries before cleaning. If you have trouble after cleaning, please restore these registry entries from the Restore center. Thank you. Now I understand more. Link to comment Share on other sites More sharing options...
