SSD Detection
Lord_Frick
 Share
how does wisecare determine if there is an ssd or not. On some systems it shows ssd optimization, but others (like the win 7 ultimate sp1 x64 machine im on now) it does not, even though windows detects it as an ssd. It is a kingdian 480, and Im wondering what heuristics it takes into account or if its just compared to a known list off ssds. Either way, is there a way for me to fix this?
Link to comment
@Lord_Frick
Hello,
Wisecleaner recognizes whether a disk is an SSD based on the rotational speed, which has nothing to do with the operating system. If there is a speed, it is an HDD, and if there is no speed, it is an SSD.
Please swich to System Monitor - Hardware Overview - Hard Drive, expand the SSD disk, do you see an option "Solid State Device"? Is the value 1?
Link to comment
  • 2 weeks later...
I am aware of this, and that was the first thing I checked. Yes it detects the SSD there, yet still doesn't display SSD optimizations. It occurs on windows 7, windows 8.1, but not windows 10, with all on the same computer and drive (three partitions). I have also toggled sata options in BIOS just to see if it would change anything, and windows correctly detects the ssd, having turned on trim and disabling the built in defragger the way it's supposed to. Iv'e also uninstalled and reinstalled the drive and ahci controllers in device manager, with the latest drivers from amd. The firmware is also the latest on this SSD. All of this leads me to believe it is a software issue, which is why I went through the time to create this account (I have previously had no issues with wisecare, using it since 2015 on all my machines from windows xp through to 10)
Link to comment
@Lord_Frick
Thanks for your feedback.
Please download and try the file. https://downloads.wisecleaner.com/debug/WiseCare365-test.zip
Note, it is not an installation file just an executable file. please extract and PASTE WiseCare365.exe to the Wise Care 365 folder. (It will overwrite the current file, but you can rename one of them to keep both files.)
Thanks,
Link to comment
Thanks, will do! And post results here. Also, just curious, but what are the main languages wisecare is written in, do you have any stuff available to the public to look at, i.e. FOSS stuff, and are you an independent, or subsidiary of someone else.
Edited by Lord_Frick
add question
Link to comment
Cool. And thank you it worked. What is different, besides the fact that it's older. Is there a code change between the regular install of that version, or debug symbols. If not, then can I uninstall and reinstall that specific version and disable update checking.
Link to comment
 Share
