Wise Folder Hider after formatting
vag32
 Share
Well, a clean install operation system? if you don't format disk (don't format the drive that the hidden files/folders are stored in ), the answer is YES, when you reinstall wise folder hider, you can find the hidden files/folders.
For example, operating system files is in C drive, the hidden files are in non C drive, if you only format C drive, it won't affect hidden files.
Link to comment
 Share
