most often a programme in virtual box fail to open saying configuration file not found. what is the solution for this problem
Operating system:Windows 7 Professional (64 bit) Service Pack 1
System root: C:Windows
Available physical memory: 6031 MB
CPU: Intel® Core i5-3210M CPU @ 2.50GHz
C: 270.45 GB
D: 97.56 GB
E: 97.66 GB
Internet Explorer: 11.0
a programme namely buyer is not opening. a box appears with a notificationn that config file not found.
C: 270.45 GB
D: 97.56 GB
E: 97.66 GB
at present I am using windows 10 techpreview as guestOS in windows 7 professional host machine. I uninstalled and reinstalled the programme. still the problem remains the same.earlier I installed this programme in windows8 to see that the same problem exists. however this programme functions smoothly in windows virtual PC with windows xp
as OS. so it is a virtualbox error
C: 270.45 GB
D: 97.56 GB
E: 97.66 GB
From virtualbox.org - End-user documentation:
In order to run VirtualBox on your machine, you need:
A supported host operating system. Presently, we support Windows (XP and later), many Linux distributions, Mac OS X, Solaris and OpenSolaris.
A supported guest operating system. Besides the user manual (see below), up-to-date information is available at "Status: Guest OSes".
And Windows 10 is not on the "guest OSes" list.
Are you saying that windows xp+virtual box can run Windows 10?
