Mihail Kosev Posted December 16, 2017 Report Share Posted December 16, 2017 There is a mistake in bulgarian translation. It is wrong: "FrmProcess.lblinfo.caption=Компютърът ти ще бъде неизползвам за няколко секунди." Correct phrase is this: "FrmProcess.lblinfo.caption=Компютърът ти ще бъде неизползваем за няколко секунди." TelemahU, Soldszar, FortopR and 3 others 6 Link to comment Share on other sites More sharing options...
xilolee Posted December 16, 2017 Report Share Posted December 16, 2017 Hi Mihail Kosev. You can open directly the bulgarian.ini (with notepad) and edit that line. Then you can upload the file here or send it to support at wisecleaner dot com Link to comment Share on other sites More sharing options...
Mihail Kosev Posted December 16, 2017 Author Report Share Posted December 16, 2017 I am sending an atachment. Link to comment Share on other sites More sharing options...
Mihail Kosev Posted December 16, 2017 Author Report Share Posted December 16, 2017 . Link to comment Share on other sites More sharing options...
Mihail Kosev Posted December 16, 2017 Author Report Share Posted December 16, 2017 I posted to the support. Link to comment Share on other sites More sharing options...
xilolee Posted December 17, 2017 Report Share Posted December 17, 2017 Yes, the forum doesn't like .ini files. The workaround is (probably) to change the extension to txt. No problem, given that you already sent it to the support. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted December 18, 2017 Report Share Posted December 18, 2017 Thanks xilolee Thanks Mihail Kosev. we will fix it soon. Link to comment Share on other sites More sharing options...
