I have now had to reinstall MS edge several times because it seems that after using Wisecare 365 4.61.439 version (after the big windows 10 creator update) it breaks my MS edge over and over again.
After using wisecare all I get is a completely white screen when trying to load egde.
It seems similar to a problem from 2015 in this topic http://forum.wisecle...edge#entry22458
Would be nice not to have to use a workaround for a 2 year old problem that should not be happening.
