Popular Post pstein Posted February 8, 2017 Popular Post Report Share Posted February 8, 2017 There are two types of scans: "Fast Scan" and "Deep Scan". Below the "Fast Scan" it is written "Only scan safe entries". From my point of view it means that "Deep Scan" is "unsafe". What is unsafe here? Is a longer scan time the only disadvantage? Peter Robertsache, BradleyTumma, MichaelAcads and 55 others 58 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted February 9, 2017 Report Share Posted February 9, 2017 Deep Scan, scan and list all entries, even though some may not be fully safe to fix.If you are computer newbie, it is not safe. Link to comment Share on other sites More sharing options...
Chim Posted March 1, 2017 Report Share Posted March 1, 2017 pstein, I have a Rule of Thumb that you can use in that area. It is the Rule of Thumb that I use when using ANY Cleaning App, especially when dealing in the Registry area. The Rule of Thumb is: If you don't know what something is (any of the items the scan found) and don't know what the consequences of removing it would be ... then leave it alone. Do NOT delete it. Do NOT allow the Cleaning App to "FIX" it. For example: In my case, when I use the Fast Scan, the Wise Registry Cleaner doesn't find anything in the ActiveX / COM Components category. However, the Deep Scan WILL find 14 items. But, in viewing the information of those 14 items that the Deep Scan finds, I don't recognize anything. I cannot decipher anything. I do not know what any of those 14 items are related to. Thus, I do not know what the consequences would be of removing any of those 14 items. So, I just leave them alone. I do not delete them. Link to comment Share on other sites More sharing options...
pstein Posted March 2, 2017 Author Report Share Posted March 2, 2017 @Chim: Your rule of thumb is nonsense. I have worked for many years in software development. I am not a Registry expert but have done a lot with Registry. So to classify changes and repairs just as "fast" and "Deep" is by far not enough. Would you buy a car when the seller just tells you "The car has great features. If you don't understand motor technique stick with your bicycle"? Or if you want to buy a computer and the seller offers you a "normal" and a "fast" model and he tells you "if you don't be familiar with computer equipment take the simple one" It is dissappointing that WiSe does not even try to list some of the advanced "deep" Registry repairs. A smart way of showing differences between "fast" and "deep" scan would be to let the user do a "deep" scan analysis at first and mark in the result list the "fast" repairs. This way the user could distinguish between the two repair items sets. Peter Link to comment Share on other sites More sharing options...
Chim Posted March 5, 2017 Report Share Posted March 5, 2017 If you had really worked in software for many years and "done a lot with registry," you would have had a better understanding of what is going on. There is a reason the WiseCleaner Administrator pretty much echos what I said, only in a more succinct manner. I have seen / read the same logic in forum after forum. Your analogies were NOT remotely the same as working with the registry. You used the analogy of BUYING a car or a computer. If you really wanted your analogies to be the same as working with the registry ... use the analogy of REPAIRING / FIXING a car or a computer. In other words, if you're NOT a good Auto Mechanic or a good Computer Technician, you should not dive into trying to FIX a car or a computer ... because very undesirable consequences can result. But ... do as you wish. I'm 100% sure you're going to think my additional commentary is nonesense as well. So, no use me trying to offer more help. Hopefully the WiseCleaner Administrator will give you the answer for which you're looking. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 7, 2017 Report Share Posted March 7, 2017 Thanks Peter and Chim. Hey Peter, you said you worked for many years in software development, it means you are not computer newbie. So, when WRC run Deep Scan, list result, and you know what are they, which one can be safely removed, which one cannot be, even if you are not a registry expert.But, if a newbie, when he see so many entries, some are checked but else are not, he may be confused, maybe he will select all entries to remove. It is very dangerous, although WRC will backup registry before clean.So, we suggest newbie or common user use Fast Scan, it is safe and fast than Deep Scan. Link to comment Share on other sites More sharing options...
Estaltboobe Posted June 13, 2017 Report Share Posted June 13, 2017 Is it possible to see which files exactly get deleted during the deep uninstallation before I agree with the deep clean? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted June 15, 2017 Report Share Posted June 15, 2017 Hey Estaltboobe, When scan complete, WRC will list all deletable entries, you can check them one by one. Only if you agree to clean, WRC won't delete an entry. Link to comment Share on other sites More sharing options...
