Godmcgarvey Posted January 1, 2017 Report Share Posted January 1, 2017 I notice the Wise365 backups all deletions which is a good thing. What I can't find is a way to limit the number of backups? Does it rely on manual deletion and if I don't will my HD become full with backed up data eventually? vapedJet, ArmandNut, Moydozzazx and 23 others 26 Link to comment Share on other sites More sharing options...
xilolee Posted January 3, 2017 Report Share Posted January 3, 2017 Hi godmcgarvey. Do you intend system restore points, when using the slimming function? Or registry backups, when using the registry cleaner? Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted January 3, 2017 Report Share Posted January 3, 2017 Hey Godmcgarvey, Wise Care 365 has two kinds backups, System Restore points and System Registry backup. System Restore Points, the backup quanlity depongs on Windows system settings, wise care 365 just list it. Registry backup, wise care 365 will do a backup before registry cleaning. we don't limit the backup quanlity, if you don't want keep so much backups, you need to delete it manually. Link to comment Share on other sites More sharing options...
