Posted
Can't open regedit
translated from turkish
error message:
kayit defteri düzenleyicisi - the registry editor
kayıt defteri düzenleme yöneticiniz tarafından devreden çıkarılmış - deactivated by editing the registry administrator
error in english:
registry editor
registry editing has been disabled by your administrator
Operating system:Windows 7 Home Basic (64 bit) Service Pack 1
System root: C:windows
Available physical memory: 6058 MB
CPU: Intel® Core i5-2430M CPU @ 2.40GHz
C: 654,69 GB
D: 29,00 GB
Internet Explorer: 11.0
Posted
Hi misterek0.
1) Have you tried to run regedit from C:\Windows?
2) Have you already used the solution proposed by wise pc 1st aid about that problem?
3) Have you already tried to use gpedit.msc (available only on professional/ultimate/enterprise versions)?
- Windows key + R key opens the run window, type gpedit.msc, press enter
- go to User Configuration --> Administrative Templates --> System, in the right pane select Prevent access to registry editing Tools and set it to Not configured or Disabled.
4) Have you already tried the other tools listed in techdows.com - 7 Ways to Fix ”Registry editing has been disabled by Your administrator “ (click) ?
